[ROM][5.07.2011][ED01]Community Rom V1.3
On my phone for some reason I can't get any of the OTB kernels to work, but a lot of people are having really good results with 1.5.
When you say that they don't work, what do you mean exactly? SOD's, poor battery life, etc? I only ask because my battery life has not been very good with OTB v1.4 and I was going to try OTB v1.5 until I saw that you, and others, were having great results with Comavolt.
I just flashed the voodoo version of Comavolt, after wiping cache and davlik or course, and I'm going to give it a ride for a while.
I get SOD with all of the OTB kernels on Comm ROM 1.3 and any undervolting. Didn't get it on CR 1.2. I've gone back to ComaVolt myself now. If I have time this weekend I may do a complete clean wipe of my phone and try OTB 1.5 to see if it's just an issue with something else lingering on my phone.
does 1.5 work good on the Comm rom?
Only been on 1.5 for 6 hour so far but i have been very impressed so far with the battery life. I don't want to clutter this thread with a screen shot, but after 6 hour I am at 70% with the screen on time being 1 hour and 25 minutes with auto brightness. Very good compared to what I have experienced so far
Sent from my SCH-I500 using Tapatalk
Bluetooth issues
My bluetooth with ComRom works then stops requiring a reboot. Both my GM vehicles worked great on 2.9.2 but on ComRom I am experiencing a lot of ups and downs bluetooth wise. I have started over from stock 2 now and same issues. any thoughts?
Ned
i may not have seen this while reading but with the miui lock the music controls are awesome the back button works fine the play/pause button works fine but the forward/skip button does not change songs it pause/plays is there a fix any were for this thanks
I believe sbrissen said it will be fixed in the next version of com rom
Reactions: T3CH9ICIAN
Oh $%&#.
I thought we where done with #@$&%#& SOD with the new ROMs!
$#&$ it!
A few other guys and myself were getting SOD with CR 1.3 but figured out that for some reason Youmail was causing the issue. Installed and no more SOD.
What theme you running, Landshark? Certain themes on superclean gave me SOD.
No Youmail here either. I have tried a bunch of different kernels and anytime I try to uv I get the SOD. Sometimes it happens in a couple hours and sometimes it takes a couple of days.
I'm running Steel Blue right now. I thought that might have been the problem initially so I reflashed Comm ROM so I had no theme, UV'd the OTB kernel, still got SOD. I've been running ComaVolt for a few days now, same full set up as before and no SOD. So the only difference between SOD and no SOD has been the kernel.
You didn't install Youmail did you?
jasminedudekula
