[ROM][5.07.2011][ED01]Community Rom V1.3
Need some help. Not sure what I am missing here. I copied TSM swipe to sd card, in CWMcleared cache/Davlik and then flashed. Nothing is different. Did I miss something. Thanks
Ignore that. I see it now. The next question is how to undo. Just redo the Community rom?
Update: It happened when the event was created in Outlook. I did another test by creating an event on my phone and it worked fine.
I should have been more specific. I have my Outlook calendar synced with my Google calendar and then use the Google Calendar Sync desktop app to keep them in sync. This is the only case where the app FCs.
I went into Google Calendar and entered an event.. When it syncs to the phone that event FCs as well. Not just Outlook affected.
I have an issue that has happened twice. I suddenly loose the modem or something. I now get a network error when trying to connect to some apps, Market, Weather Bug, etc. It was working fine then suddenly dropped. This happened last night and I had to restore back to stock and do the OTS upgrade and the Com Rom update.
Any thoughts? I tried the EC01 radio but that made no difference.
Outside of a radio reflash I am not sure what will change that..
Will the comavolt kernal work with this rom?
sent from my kang bang fascinate
So far I am liking this rom. I just have two quick questions, what vodoo kernel are you guys using? and I noticed that hitting the volume button wakes the phone up, any way to disable this?
Does this issue only apply to the stock Google calendar? I'm running touchdown and I'm wondering if that is impacted (I'm not on the new ROM yet).
Not sure.. I have only run the stock calendar..
I have seen a post from one person who is using the ED01 radio (quick install method by Adryn) - and has not applied the v1.1 patch who does not have this problem..
Reactions: ITF36059
it is strange because I can still call/msg and browse. Is it a 3g thing?
If you are still able to connect to the network to browse then there is some other setting that is prohibiting those apps from connecting. You can still get emails?
I looked at your original post the two apps you have listed "Market" and "Weather Bug" have a history of having network connection problems.. they have happened to me..
Reactions: rogerg
Which clockwork does this rom need to be used with? It shows edify in the changelog, but I wasn't sure. Right now, I'm using Clockwork All (the one that boots directly into red without the errors) - is that the right one or do we need CWM3 (orange)? Thanks in advance.
Odd... Flashed the 1.1 patch. Everything looked good up to the home screen. Then a reboot loop started. the boot loop still going. What do I do?
Update: On the 4th boot loop I immediately unlocked screen. I have Launcher Pro as my home launcher & tried switching to stock TW before another boot loop could start to see if LP might be the culprit... Boot loop ended. Waited another 5 minutes... Went back to LP, and everything is running great now... Go figure.
Okay here is a fix for the Force Close on the calendar notifications.. nitsuj14 identified that the theming of the calendar may be at fault and offered the TouchWhiz calendar unthemed - it works - no FC's...
Here is a link - Flash in CWM..
Enjoy.. This ROM just got perfect..
i am trying to odin the ec01 radio right now and after i clicked start it said initializing and then says get pit for mapping. nothing appears to be happening right now. any ideas?
Wow what a quick response. Thanks!
You guys are really killin me. Initially I had no intention of ever rooting my phone, but then I rooted it because of you all. Then I flashed some stuff with Odin.. and had no intention of ever using CWM or going voodoo. But now I've done some more reading and I just have to try out this Community ROM, plus I want to flash back the Daily Briefing Widget. So tonight when I get home I will install CWM Red, go voodoo and get the party started! (I wish I could install CWM without needing a computer..I'm not able to do it using my office PC).
My question is.. I'm rooted and ODIN flashed to ED01 using Landshark's ODIN file. Do I have to wipe all data if I want the community ROM? I'd really rather not wipe if possible.
Thanks!
Bump... anyone? Do I have to wipe my data to flash the community ROM?
ajr81
