sushiguy732
- Jan 11, 2011
- 1,351
- 46
- 0
Taking the 1.3 plunge now.... rebooting... wish me luck!!
Good luck, hopefully all goes well for you. If not let us know what's wrong.
Is it me or is the speed on 1.3 SUPER fast? I am not one to hype "this is the fastest rom I have ever been on" but it does seem a LOT faster than even 1.2.
Thanks you Comm Rom Team!
You may have issues with phone calls and SMS messaging, or you may not at all. If things are going fine the way the are for you now, by all means, stick with it. If you notice problems then I would definitely consider updating the radio/modem. As far as I know Odin is the only way to apply the radio, but there's the chance I could be mistaken, their may be a way to do it in cwm, if someone else knows I hope they chime in.
thanks again: already had issues with calls & stock SMS random crashes. should have known to check. best radio to use?
It's debated between EC01 and ED01... some believe they are pretty much identical since EC01 is believed to be the leaked and almost identical version of ED01.. You'd probably be fine flashing EC01. In order to get ED01 you would have to convert back to stock and update via OTA or update.zip method to ED01 which is the official release from VZW/Samsung for the fascinate.
so TIL a bit more & all gellin' a bit finally. so if build# is E-series radio maybe should be too?
Yeah, I mean it doesn't HAVE to be, but in my experience I like to keep them the same. I've never had problems that way. I was one of the people that reverted to stock updated to ED01 via OTA update and then flashed the rom that way I had the official ED01 radio. But like I said many people believe EC01 and ED01 to be practically identical. It's a lot easier to just flash the EC01 radio than to go through the motions of reverting to stock and updating.
i'm going to be looking for a "non-take-case-off" (odin: start dinosaur PC, crawl into wire jungle to plug USB into back port, etc. gotta be a cwm way?) way to do EC10...
Is anyone else getting the verizon sound with the shutdown animation now. Never had it happen before and now I am getting it every time .... ???
ED01 has not impressed me much. I remember when I got the fascinate, I was amazed at the signal strength. I live is a zone where 3g is hit and miss. My D1 dropped calls like crazy. EC01 and ED01 have not been that great for me. GPS seems fine but 3g and 1g not so much. Anyone using EB01 or DL09?![]()
This information was posted by Sfobrien earlier in this thread...
If you have root explorer (or similiar) go to System>Media>Audio>UI then delete the poweroff.ogg file to remove shutdown sound
That will remove the sound if you want.
Is it just me or did we lose the clock in the upper right hand corner of the screen.
If you go into Setting / TSM Parts / Status Bar Settings there are a ton of options there.
But... When I try them nothing seems to work right... This is the only issue I have so far with this build. I hope they fix it. Gunner.... Can you bend their ears on this one??
