[ROM][5.07.2011][ED01]Community Rom V1.3
ah, the old...
Go menu=>settings=>TSM parts=>statusbar settings and make sure there is no checkmark on hide clock then go down to text color, touch the outer circle near the white area then touch the circle in the middle, back out and try flipping the phone sideways so the screen goes from portrait to landscape. If that doesn't make the clock appear, just do a reboot and the new settings will take effect.
EDIT - also if you want the AM/PM to show make sure there is not a checkmark in Hide AM/PM
... color wheel trick, \o/
needed reboot 4 me.
voodoo
oooohhhhhooooo, in cwm red all recovery it kept saying voodoo off, enabled on next reboot, but no, not even after manual enable & reboot, so for s&g did manual disable & reboot. now it's talking (1st time eva) on reboot, samsung logo, .... "voodoo lagfix now disabled", 'droid logo..., booted...
edit: seems just as fast, def much better, com rom rocks. many thanks to all.
edit 2: so 4 more s&g went back thru cwm red all and it said voodoo disabled, next boot disabled, chose enable, rebooted and it talked a long time then ".. lagfix enabled" & w00t everthing seems "even snappier" tm than b4, dang this rocks.
dl09 radio GPS
ED01 has not impressed me much. I remember when I got the fascinate, I was amazed at the signal strength. I live is a zone where 3g is hit and miss. My D1 dropped calls like crazy. EC01 and ED01 have not been that great for me. GPS seems fine but 3g and 1g not so much. Anyone using EB01 or DL09? ;)
i'm stuck at dl09, anything in particular i can test? normally don't turn on any location services so not much prior experience. it's always managed to get within rock toss distance anyway, and still is, suppose just using cell towers.
My GPS has been loosing its signal like crazy since flashing CommRomm v1.3 like every couple minutes
If you're not having any reception issues or any other issues currently, then you're probably safe to stick with what you've got. EC01 is as easy as flashing in odin tho if you ever decide to try that out.
Reactions: anub
Are you running Tasker? I've noticed that Navigation is losing gps lock every few minutes until I turn Tasker off. If I turn it back on again then the gps problems come back.
May be a silly solution, but try a *228 opt 1 opt 2 (not sure if the options are correct) maybe the PRL is out of wack since the flash
'dozin
just boot camped my mbp w/ 'doze 7p, headin' in to odin 'dis e-series radio, wish me luck... ;)
ha
What? Not sure I understand what you mean, your last post kind of confused me too lol. Boot camp 'doze?
lol, finally got logged in in this boot camp winDoze 7 (pro 64bit) got fing Odin dl'd & ready, now 2 dl a radio... hmmm... search for ec10?
no worries...
check the themes, how to, sticky. so many to choose from . No ec10, though....how's Ec01 sound?
got the *gasp* EC01 modem, ugh, that's not EC10, so confused...
edit: yes, utterly lost in acronym / version land
edit 2: \o/
Is the problem where third party app lockscreens no longer work proper fixed yet in 1.3? (e.g. - In poweramp, the lock screen direct unlock no longer works properly, I have to go through 2 lockscreens to unlock now)
Doesn't work for me on 1.3. Still gotta go thru two locks.
dumpsterrentals89
