[ROM][5.07.2011][ED01]Community Rom V1.3
Finally got 1.3 to stick. Was getting alot of FC's and had to flash a browserr patch to fix it... So far so good.
Although not feeling this swype theme...
Sent from my SCH-I500 using Tapatalk
Cool... Suicide Shift said he went back and wiped data AFTER installing comrom and didn't really notice any difference..I wiped data before installing, but not AFTER, and haven't really noticed any major problems.
I am pretty sure I have read on XDA that Adry recommends leaving Google Locations Services on all the time, as contrary to what my/our logic tells me, he claims it doesn't drain your battery.
I found leaving it on helps with gps/navigation when I go to use it..
Did my data wipe prior to flashing 1.3 as well, no major issues so far. I leave the Google location services off with only standalone GPS enabled. My GPS locks on faster than ever before. It is amazing how the same device works so differently for every user.
Go Launcher icons in task bar turned to plus symbols overnight while charging: "+++++".
Booted into red cwm all and fixed permissions, now icons are back. \o/
funniest rom yet :confused::eek::cool:
Anyone else having Swype issues? It doesn't save words for me, which is a real pain. Other than that, this rom is fantastic. Keep up the great work guys :)
Try clearing your Swype application data in settings--applications..
I like to do that every couple weeks to clear out all the typo's it stores and I'm too lazy to go through the whole proper typo correction..
Reactions: stilltipin87
Ok, I'll try that. Thanks. Also, when I applied the Miui/Ginger Hybrid theme the tsm parts disappeared from the settings list.
Yeah, a theme will remove TSM parts from settings. I have included TSM partsv1.0 and the lockscreen application .apk's over on my thread.
http://forum.androidcentral.com/verizon-fascinate-rooting-roms-hacks/82298-how-changing-out-themed-swype-apk.html Post #2
Adding TSM parts back will un-theme your settings and status bar again. I just added the lockscreen settings .apk back to get access to all the lockscreens/music controls while keeping my themed status bar. I've got instructions over on the thread.
Hope that helps streebs.
anyone having trouble with the MIUI lockscreen music control?
I can't seem to get the "next music" button working
Having issues with LauncherPro FC related to bookmarks. Tried reinstalling and and was working fine until added the bookmarks widget. Unfortunately, it now closes before having a chance to remove the widget. (Is there any other way to remove it besides long press?) For what it's worth, I deleted all bookmarks, but still FC. I'm not crazy about rebuilding my 7 launcher screens again from scratch.
Check the OP and flash the browser patch for 1.3 and see if that helps.
is there an easy fix for the miui lock screen to get texts number show up when i get them like it does for missed calls? thanks
For some reason I can't get my clock o date to show up on my statusbar even after checking tsm settings,any ideas
Loving 1.3! Aside from the invisible clock (super easy to fix), everything is running super smooth! A great job!
gruptysh
