[ROM][5/23/12][4.0.4][AXI0M] CROSSBREED and PATIENT ZERO
Re: [ROM][4/11/12][4.0.4] AXI0M - Roms by DroidTh3ory
So Is having the Axi0m ROM, ROM Mananger app and franco kernel updater app the basic stuff I need to overclock, underclock and otherwise go wild on my GN?
More or less, yes :D.
The rom may have some controls over overlocking, etc., but that's usually through the kernel. Franco makes kernels. Roms will come with different kernels; some their own make, some like imoseyens (the lean kernel), franco, trinity, etc. What's great about the updater app is that you have so many controls over the kernel in that app. It's really my one-shot stop for overclocking, volting, etc.
Reactions: blue duck butter
Incredible. Kudos to all developers. Who do I paypal donate to? Are there certain factions that are doing this? In webOS, it was easy to donate to webOS Internals, headed by Rod Whitby. Is there anything like that here? Is it too fragmented to sensibly donate? If need be, I will alpha test various projects. PM me.
You could (and should ;)) always donate to DroidTh3ory. Check out the droidHIVE link for PatientZero and click donate.
The franco updater is paid, but you could also find him on RootzWiki or XDA and donate through there as well.
I'd also LOVE to be a tester lol
No problem ;).
How's the OP redo look? Still some work to do...had to change the title b/c I ran out of space lol
I noticed the title first and was like "haha yeah that's about what you have to call it at this point..."
OP is nicely organized... I would probably say you can drop the crossbreed section because that's dead... And really once MORFR is complete you should be able to consolidate everything into once section just under MORFR... as that will be the base (well, Driven will be).. then the modules could each get a section. I imagine that's how its going to work, as th3ory did similar projects for the bionic called SHIFT3R and then KIN3TX and they both followed that same kind of organization. MORFR is going to be a whole different kind of beast though... since each module is going to basically make you a different ROM.. That's insane. I can't wait to see this. :)
I got off track... Nice job DM! :D
Thinking about it, might even be a fair idea to start a new thread, lol. I'm sure Th3ory is going to on the hive for this, its a new project altogether. Your choice tho, obv, doesn't make much difference ;)
Regarding donations.. guys can donate to th3ory directly on droidhive.com.. he certainly deserves it. FWIW, I'd say its probably a nice idea to throw a donation toward the ROM devs making all the swag you use, or are going to use, for the MORFR modules, whether it be Roman and the AOKP team, CM9, CNA, whatever... you can find all their info easy enough in the nexus section on rootzwiki. I've thrown a number of donations th3ory's way since I got my bionic in september, lol... have been meaning to throw some dough toward AOKP for a couple weeks now since we've been enjoying all their swag in Patient Zero / Crossbreed.. keep forgetting lol. :-[
I may start a new one or remove Crossbreed (and just simply link to it) and make it PZ + MORFR. That should clean it up nicely into 2 parts, right? I don't want folks to get confused lol
Right, I only say it because, technically, crossbreed is dead and PZ is more or less dead. Going forward its all MORFR. A new thread is a nice clean slate... but hey, you're the boss here ;)
Don't worry, a full scale rewrite is happening when I get home ;-)
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk
Reactions: 2defmouze
Cleaning up this and a separate thread is coming
Guess what theory just gave me to play with....... :D
Re: [rom][4/11/12][4.0.4] axi0m - crossbreed & patient zero
First, you're a dick.
Second, WTF w/ no caps in the title.
Third, post in the correct thread, noob. :D
I just asked him whether or not we can flash softkeys w/ ZipThemer. Hopefully we can. If so, I want to know which file we configure/update edify with--the base or the package.
Anywho, let's take MORFR discussion to its own thread :D.
Re: [ROM][4/11/12][4.0.4][AXI0M] CROSSBREED and PATIENT ZERO
So, totally new here still. What advantage will MORFR have over the AXI0M Patient Zero ROM I'm running now with franco kernel?
Read the OP, lol... new base, new ROM, totally new system... Patient zero is ending, I believe, while it will live on as the AOKP module you can flash on top of the MORPHR base. All updates going forward will be under MORPHR. :)
EDIT: Sorry I meant read the OP for MORPHR, lol... didn't mean to be misleading
Yup and hang tight because it's being fixed lol
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
Reactions: zero neck
I flashed Patient Zero because of the issues I was having with stock 4.0.2. Among these issues I was having problems sending mms will I'm still having this problem. Anyone else having this problem? Is there a fix?
r3dpuk3
