[ROM][5/23/12][4.0.4][AXI0M] CROSSBREED and PATIENT ZERO
I flashed Patient Zero because of the issues I was having with stock 4.0.2. Among these issues I was having problems sending mms will I'm still having this problem. Anyone else having this problem? Is there a fix?
I've always been able to send mms aside from a cm9 build. What happens exactly?
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
It gets caught up on sending. If I rest my phone it still gets caught up. Driving me nuts.
I think it may be the switch with wifi on. I, just did a test and made sure I turned wifi of prior and it sent. I usually just leave wifi on.
Re: [ROM][4/11/12][4.0.4][AXI0M] CROSSBREED and PATIENT ZERO
The download link isn't working to Patent Zero M1 download to flash. Is there another one I can get?
The rombot is down.
I'm waiting for the dropbox upload to finish then I will post a mirror to the OP.
Edit: Mirror link posted in the OP.
I'm on Black Exodus 3.4 and it is epic
Is there a separate PZ download, or did you just use the one for AOKP?
May try it before work. I like to try Black Exodus every month, just to see what's what.
DMmarck.....verizon screwed me over by not calling my *ss back.
So since I am rooted stock, I want to flash PZ but your links in the first post are dead on my end...towards the end you have a file with a dropbox mirror.
Doesn't work for me...:eek:
tony - lol excellent.
I'll check the link when I get a chance and swap the file for another. I might have reached a limit; no idea, never used dropbox like this before!
Sry don't have a copy. I thought he abandoned the UI revert a few builds back.
Well this hasn't been bumped in a while.. had to search for it! Lol good reason though.. Patient Zero v20 is up on droidhive :)
Reactions: dmmarck
Re: [ROM][5/4/12][4.0.4][AXI0M] CROSSBREED and PATIENT ZERO
CMPLX V2 is coming out today, so I'm just waiting on that ;). Will update/redo the thread when I have time...stupid exams.
richardgroover
