[ROM][6/26/12] CyanogenMod 9 - Official Nightly & RC Builds!
Re: [ROM][6/19/12] CyanogenMod Nightly Builds - OFFICIAL!
Hows it going guys, Im running the Gnex with Euroskank CM9 (9-2012617-SKANK-toroplus) with franco kernel(3.0.8), using Apex launcher(v1.2.2) and I cannot get the camera to work since I flashed the CM9 mod. I have since flashed aokp build 39, and Miui 2.6.15 V4 and still cant get it to work. (I honestly did not try with Miui
Am I missing something? Has anyone else had this issue? I went back to the first setup above.
First off... are you doing a FULL wipe when flashing different ROMs? If not, make sure you do so.
Second, are you flashing the correct ROMs for your nexus? Verizon Nexus is Toro, Sprint Nexus is Toroplus... I see the CM9 build you said you were running is Toroplus.. if its not the correct ROM for your device then, well, that will be the problem, lol.
Yes, complete wipe, and Im on Sprint, if I posted in the Sprint forum Id never get a response lol. Any other ideas?
Does it work with other camera apps (like instagram and the like)?
Ive never really used instagram but I downloaded to see if it would work and it doesnt seem to save. the camera does the whole auto focus and everything and in instagram it will "hold" the picture after I click the button but nothing will save.
update - I wiped and flashed back to the baseline I had saved from right after installing cwm and even on the stock img the camera had stopped working. On the stock flash the little gallery preview on the right side of the camera does not show up, and in the gallery it doesnt access the pictures I have taken at all.
I think it has to do with the steps in the root toolkit. I believe I may have rooted and then done another step instead of reloading my data. I might just start from scratch again.
Read this thread: http://forums.androidcentral.com/ve...ing-roms-hacks/180368-camera-not-working.html
I think the basic problem was restoring old data after rooting and or flashing screwed the camera up.
So I went and got the camera working by going back and unrooting/flashing stock img back to the phone... except... When I did that cm9 still booted to the phone! I even relocked it and unlocked it again.
The good news though is that I as able to keep my data, and everything seems to be working now. except when I go to storage in the settings menu "setting" force closes.
oh well works for me
Anyone know if the screen shot on the power button long press works?
Not sure, but the vol down button/power button option should still be fine, and requires less work. :)
That didn't work for me either, I never really use but I wonder what it could be that is causing the problem.
Anyone else looking forward to the next nightly with updated CM wallpapers!
Gerrit Code Review
And of course more rom fixes too!
Re: [ROM][6/26/12] Official CyanogenMod - Nightly & RC Builds!
Updated with 6/25 nightlies PLUS the 6/26 Maguro/GSM RC1!
Reactions: 00_wrath_00
All Galaxy Nexus models have an RC1. Please check the OP for your corresponding model, and also, don't forget GAPPs!
Should we do a full wipe before install of the rc, or just do the standard dalvek/cache wipe?
sonamsing09
