[ROM][AA][EXT4] AnonymousROM i3 [2.3]
Awesome ROM, have been using it for almost three days now :)
Everything is working just great, the battery life sucks, but that is not new.
Keep up the good work.
Anyone else having memory leak issues with this? I've had it since the day after it was released and recently noticed that there are times when my memory gets used up. I'll restart the phone and when it comes back up I'll have 150 available ram. Within an hour or so it'll be back up to only 25 ram free. And that's without running anything or making any calls, etc.
Should I just redo the OS or is this a known thing with the i3 rom?
android devices use memory differently. Windows low free ram bad. No room to process.
Android stores the entire app in memory so it will be ready to roll when you need it. So android low ram is good. Need more info Google android and task killers.
I have to disagree with this comment. Before I rooted and installed this Rom, I was getting an average of 18 hours battery life. I installed the Basic GB 2.3.3 Rom with EF02 and got about 26 hours. I installed this Rom and got about 24 hours for the first couple days. Then I went to do the Battery reset procedure and ended up wiping the wrong data. That prompted me to restore my backup and do the reset procedure again. After that I have currently 3d0h57m47s on battery and 39% battery left. I will take a picture of my battery life when I get closer to 15% which I estimate will be tomorrow morning when I wake up. I have not surfed the net, turned on wifi, turned on BT, accessed email, accessed the market place, or used the overclock on this since last restore. I have made phone calls, used sms, used the camera, and set my alarm clock the last three days. After this test is complete, I will test it out with Wifi enabled and that's it. No surfing the net or anything else. I want to see what exactly drains my battery the most. I think it might be Wifi searching for signal in my case so this will prove that true or not.
well sad to report not but 2 hours after posting this, my phone shut down and rebooted itself. Been working fine since, however the battery time changed. it was almost like it went back a full day. I will be charging it now and restarting my timer. Battery says 2days now when it should say 3. will keep you posted.
For some reason my wireless tether app tells me that I don't have root but I can still tether. Does that happen to anyone else?
çhimezie
