[ROM] AC-ROM-Froyo 2.2
Would everyone want stock apps(bloatware) removed?
  • Total voters
  • Poll closed .
Great info there, thanks. the only problem is that the radios on the wiki are on mediafire too. i was actually already on xda's forum looking for an updated version. no luck yet.
Hey beezy, how's it goin? I remember I talked to you last when you were just starting out on xda. Hey, without downloading, whose kernel are you using specifically?
Hey bro,glad to see you around. It a kernel I compiled from HTC source,nothing to special just added OC/UV.
It's late and the stupid PRI thing has my brain fried right now. lol. Thanks for the assistance.
Hey guys,
Just updated to latest version last night and wanted you to know that it is amazing. Battery lasted literally 12 hours with moderatge usage, and it is just so smooth. Thank you all for your hard work and this is the ROM I tell people to use. THANK YOU ALL!
I don't seem to have the WiFi tether app anymore?
Any idea where I can find it and how to install it?
From my HTC EVO using Tapatalk pro.
I think I found it in the market. Under wireless tether for root users....
I don't understand what's wrong with this Damn thing.
It just sits at "identifying...." and never connects???
Why?
Wireless tether questions should probably go in that thread and not this one but to answer your question....
The reason It's not working is because you downloaded it from the market. You need to download it from the Google code page for that project because pre 8 is the version that works with froyo on the EVO but not the version found in the market.
Cheers.
Edit - I just noticed pre 9 is out. I have not personally used pre 9 so I can't tell you if/how it works but either way pre 8 and pre 9 can be found right on the Google code page for wireless tether.
Prl and Pri
I don't have the latest two versions. Can i just update via the update option on the phone or do I have to do something else? I don't wanna mess up my root or my AC ROM. Phone is doing wonderful would hate to mess it up.
You have to wait until they update the ROM to get the updates for wireless tether.
I think he's talking about PRI/PRL (i just noticed he titled his post). I was confused too.
Well here's the thing, you can update your PRL anytime you want no problem. Menu > Settings > system update > Update PRL that should do the trick. This doesnt wipe any data or anything.
Now if you want to update you're PRI that's a whole different story. you could be flashing and wiping for days lol. The trick to it is though to NAND backup before you do anything. That way once you get your PRI situated you can NAND restore and be all set.
Oops sorry I didn't see the post title. If you try to update the PRI make sure you have lot's of tylenol/aspirin. It's a PITA. I gave up after three days and haven't regained the patience to try again.
Make sure you do a NAND backup before you mess with the PRI. PRL is usually problem free.
thattoiletguy
