I been running set cpu, I been turning it way down during non usage and it seems too save battery, should I not be doing this?
From my HTC EVO using Tapatalk pro.
I'm currently at 26% battery with 7 hours off the charger, I should be getting better then this, this is with set cpu and my screen brightness turned down to the letter U in automatic.
Well my phone rebooted itself, so now I don't have access to any of that info, but I remember it wasnt the same.
How do I do that?
Do you adb set up on your pc?
If you do open command prompt and type
adb shell (which should return # sign)Then type or copy&paste this
top -m 5 -n 1
That should give you a print out of the top 5 processes.
thats what i just got now, would u like me to do the same after a full day of usage to see whats draining my battery?
I have been running the latest AC Rom for a while now, probably a few days after it was released and I am having a problem.
When my phone is on standby sometimes I get calls and the phone will not ring. I will go to use it and I find that I had a call or even an email. Anyone else have that issue? It seems like it goes into a deep sleep and will not wake up to notify me.
Other than that I have no issues. Thanks for the help and any thoughts.
Thanks for the quick reply.
I am running the ROM as you have put it out. I used to have Blackberries and I am tired of playing around with roms. The days of loading hybrids and tinkering with them are behind me. LOL
I will read the lick you posted. I had feeling that it had nothing to do with the rom.
