[ROM] AC-ROM-Froyo 2.2
Would everyone want stock apps(bloatware) removed?
  • Total voters
  • Poll closed .
Tried installing the full version and all I get once I boot is a red triangle. after rebooting I get the following message:
e: Can't open /cache/recovery/command
--install form SD card...
Finding update package...
opening update package...
verifying update package..
E: failed to open /sdcard/update.zip (no such file or directory)
E:signature verification failed
instalation aborted
Edited on 8/18 for cleanliness - As gbhil pointed out, user was trying to install a ROM without a recovery image. Please reference these rules
Downloading from a PC. I unzipped the files and pasted in the SD card. I also left the whole .zip file in there just in case. When I open the .zip file to look for this update.zip it's not in there.
I have a question. I Flashed to the full 2.2 Rom with no issues and love it. One thing though, I am leaking battery power like my evo was made by BP. About 1% every 3 minutes. It doesn't matter what i clock the processor to or what's on or off. I was at 99% charge exactly one hour ago. I unplugged and restarted. Went to android central and browsed. I'm at 53% now. Any ideas?
Did you make sure to turn off location like stated in post 2?
Convertpad
Battery droid
Google sky map
Google goggles
Google translator
Setcpu
Shop savvy
Papertoss
Steel shot
The weather channel
Trap
Wells Fargo
Word search
Pretty lite list...I wanted to just mess with the things it came with before going to wild.
Convertpad
Have you ever used spare part? Open it go to battery history and it should allow you to see what is using the most cpu then let me know what it says please.
Internet. 26 6146774ms
Clock. 6 2720306ms
Messaging. 26 2693650ms
HTC sense. 114 2301933ms
Drops to 239001ms from there.
Clock. 6 2720306ms
my bad i should of gave a little more detail of what i wanted you to do.Open spare parts,choose battery history,where it says other usage change that to cpu usage.It should look like the pic attached.(if you want grab 'shootme" from market and just take a screenshot that way you don't have to type it out.)
hey thanks for the tip on that!
That doesn't really show anything out of the ordinary,im going to PM you soon with some instructions to help pin point the issue. One last shot in the dark do you have all your accounts set up to sync a lot like every 15min? If so change and see how things go,If not disregart the question?
Yeah, after reading countless threads in diferent forums and trying to flash my phone several times, I figure that it can't be done. When I try to reboot in recovery mode all I get is a picture with a phone and a red triangle. FML. Can anyone shine a light in something else I could be doing wrong? I downloaded a new file did not unzip it and I have on the root of the card...
You don't have a custom recovery image installed. Please have a look here:
http://forum.androidcentral.com/htc...-your-htc-evo-install-clockwork-recovery.html
In effort to keep the ROM developers free to work on their ROMs, have a look at our new rules
http://forum.androidcentral.com/htc...s-hacks-forum-please-read-before-posting.html
If you still are having issues after you've read up on the recovery, feel free to start a new thread, lots of us here to help!
Thanks alot. I look forward to it. I appreciate your help and time. Love the ROM and hope to this small glitch fixed.. Other that the one issue this ROM is nails. I love it.
Well, this might finally motivate me to update to 2.2. One quick question:
I'm on the last 2.1 ROM, rooted with unrevoked 3. Can I apply this to what I have now, or will I need to use something like simpleroot first?
Thanks,
Hey is anyone having issues with sound quality. everything else is working flawlessly except sound quality ex music
Thanks,
Ive never used unrevoked,but you need root access and nand unlocked.Thats the best way to go full root.^links above in gbhil's post.
If you mean like pandora and stuff like that,then theres a article about music and froyo on front page of AC.
*Edit here's a link to it. http://www.androidcentral.com/fix-coming-froyo-audio-issues
kitlis
