- Nov 25, 2010
- 15,958
- 2,752
- 0
I will double check the images, could be a mistake on my part. If I can find an error it will be updated in the next update.Seems like nothing can really be done about it on your end- its just a bug.
According to the dev of the battery mod he said no it doesn't use any more battery than the stock meter.Does this mod actively use battery life moreso than the stock indicator? I know some of the Market apps cause increased battery drain, but this rom seems to be doing very well on battery (if I can ever stop using it).
Yes it was there on Eclair too. I was hoping that the official Froyo elease would fix this bug, but it doesn't look like it was address especially since "stock" is still the bogus 10% increment battery imageActually, are you sure this is a Froyo bug at all? My phone on ECLAIR came off the charger at 97% according to Quick Battery (which I had to use since the stock notification batt icon sucks). Its not really a big deal to me- I have managed (on eclair; havent tried on Froyo) to get it to 99% with a few unplug/replugs. With the ACE rom though (and the noobnl andromeda rom when I was on Eclair), battery life is good enough that I dont really care/bother.
