slutyman321
- Dec 9, 2011
- 94
- 4
- 0
can someone help with every rom i flash i cant conect to my google account and the one time i did play store did not work what can i do
i miss my optimus vi want to try this rom..lol
Me too gave it to my sis with this rom on it ........ she lost it in a week![]()
Sent from my One V using Tapatalk 2
I'm loving it! I haven't tried paranoid android yet. I've only ran a couple roms since most of them are all in beta. But titanium kernel isn't ours >_< ours is sickkernal same thing just for the cdma version. But if you have to money I say get it! Its pretty amazing. Even with only a few devs. Plus sellers Leslie and gannon (never can spell his new name haha) are all getting it or have it already! So the one v devs list will be getting some familiar faces ^_^Aww, I once did that with an iPod and she had it locked within a day...
How are you liking the One V? I've been considering getting it as an upgrade, and then rooting it, running Paranoid Android, and installing Titanium Kernel to overclock around 1.8 GHz.
Open the statusbar file, you should be able to figure out how to incorporate those into a rom. However, they are optional.
Does it have to be the stock rom we take the img's from? or can it be another custom rom for the same device?
I keep having an issue with this, tearing it apart and playing with it so i am learning but, anyway the issue i am having that everything flashes fine and seems to go through, the only thing is it gets stuck on the android(i used the one from H2 since i liked that) screen after the LG screen in infinite loop. I am sure it is a simple fix, but for some reason i can't figure it out tried complete wipe and reflash. Still trying to figure it out myself, but I flashed back to H2 for now.
Did you resign the framework-res.apk after replacing the bootimage asset?
Be careful messing with framework, my advice is never fully open it, just use something to see inside, and then drag and drop any changes you need to make. Otherwise you can very easily mess it up.
Another thing is not to leave it open too long in Winrar and Winzip or whatever you are using because depending on how Windows is configured it can start to purge some of the temp files before it has a chance to close it back up, at which point your framework, and even your entire rom zip can become corrupt. This this may not be what is happening, but the best explanation I have for why it randomly ends up corrupting when open too long, regardless the only fix is to start with a fresh copy and drag in your changes.
