[ROM] Aeneas Froyo Build Your Own Rom 13June12
Its not uploaded yet. (The version with black status bar). I'm waiting to see if anthonycr is going to cook us up a theme. Not many people are taking an interest in my rom anyway its sad /:
It takes a bit to build trust, plus this is Froyo... It's not as exciting. Don't build for others, build for yourself. Harmonia has always been primarily what I wanted. If others liked it, great.
It seems better that way, that way I know the audience will like what I make.
Building for yourself is always better that is how you well know if your work is good, because if you like it then others well too.
Right now my recovery build is more popular then my rom build.
I've been using your Harmonia 2 for a couple months now. It's the best I've found. :) thanks
YAY!!!!!!
The IHO version is ready, all I have to do is put together some README'S, on how to install and use. You well need to install the Cgywin Packages I have put together first.
As Cygwin is a Unix like System for Windows which means this version uses Unix bash/shell scripts, however this well not work in Linux by design, if you want to build on Linux, then build from source it is more nerdy fun.
YAY!!!!!!
Wooot!!!! Cant wait to try it!
I'l have it upload tonight and ready by tomorrow morning 10 a.m. MST. The Cygwin packages I had were from an earlier install of Windows so was not able to use those. So the Cygwin install is now a two step process because I'm to lazy to put them together again.
Haha OK. Thanks! Either way, a lot if people are going to try it thanks for your hard work!
And I own a big thanks to blarf, LeslieAnn, JerryScripts, mrg666 and to many more. Cause truthfully I've only been doing this for a little over four months, and I learned a lot from them.
they really are great! I wish we could do more than just thank them and click the thanks/like button
download link does not work.................where can you find one that does or is it just a fluke..............i have been manipulating ROMS for a little while now........can't develop what is not there?????????????:cool:
Ill check this out later today, sounds like a nice pre-build / build starter.
luigui443
