ARCHIVED: [ROM][ALPHA] quattrimus ICS
Status
Not open for further replies.
You can get a free one from the Play store from inside Apollo. Menu (three vertical dots), settings, under Interface press themes, get more themes.
But does it come with a matching widget? I couldn't find a way to change the color of the widget to match the black theme besides installing this apk.
Settings>Themes.
I've tried using it, but every time I try downloading something from the market it gives me "purchase error", I flashed dalvik and everything but nothing.
These work.
[CM9/AOKP][THEMES][MDPI]**FULLY MDPI supported themes**[APKS ADDED FOR HOLO SERIES] - xda-developers
http://forums.androidcentral.com/op...-slate-afterburner-volcano-etc-hdpi-mdpi.html
http://forums.androidcentral.com/lg...7-xperia-s-theme-cm7-cm9-update-6-4-12-a.html
Running anthonycr Yellow Bird, easier on these old eyes than cyan on black.
I hardly use widgets, so just tried, and no, it is white, so only theme in Apollo is black.
Why did theme devs give up on MDPI? It doesn't seem like a dead "format" to me..
Well there are alot but not on play store. The only that come to mind that have mdpi support on play store are anthonys themes and holo themes. But there is bunch on xda
Hey tdm, quick question for you. Can you think of any reason why flashing the pre-beta would have bricked my phone?
I hope you're not thinking that brick = bootloop
Popular misconception. Brick would render your phone brick like and not be able to be used. If you're bootlooped wipe and start over.
Reactions: inceyet
Latest nightly via romkeeper (check date of this post) - MMS is not working for me.
Sending or Receiving. Anyone care to confirm?
Surprise no one mentioned this. But if you change the LCD density to 140 you can use the (x)hdpi themes.
ETA's kill puppies. Sent from my ______ using Tapatalk.
TDM awesome rom ! It runs real smooth and fast. Nice work and great progress man!! :cool:
Thank you and all Devs involved!:D
Reactions: tdm
I get the MMS message itself, but won't download the pic. Just sits on downloading. Using Handcent
Sent from my ZombieICS-VM670 using Xparent Blue Tapatalk 2
Yeah, my bad. :P
Boot looping, but ADB doesn't recognize it, and I can't get to recovery.
I'll stop derailing now.
Status
mersy78
