[ROM][ALPHA][WIP][ICS]: CodenameAndroid
I'm 95% sure the split screen is something in bobs device and vendor blobs. And its caused by having a sd-ext partition. And I'd gladly add the script if I knew how. :p. I'll talk to tdm about that, may be in a coming update. I'll update tomorrow and add apollo. Glad it works for you though :D
Sent from my VM670 using Tapatalk
Thanks I had no music at work so I had to make my own and let's just say my co workers don't like me singing :D lol
Sent from my VM670 using Tapatalk 2
Reactions: inceyet
Lol that's great. I will try to have an update with a music player tomorrow.
Reactions: topdawg661
Works pretty good, the only issue I'm having is I can't get the navigation keys at the bottom of the screen, not a big issue but my home button has quit working so I've gotten use to using them on aokp, but still great job
Reactions: sellers86
Well I just got my first storage space issue :p installing from TB I got a that flag come up I think its because it may nit be using the SD next partion :confused: correct me if I'm wrong (never had this issue come up on any of the other ics roms) ...also when turning on caps lock then turning off keyboard letters stay caped but just gotta tap cap button on/off to correct it not a major issue just reporting :p... will be back with some oc finds later. Great work sellers
Sent from my VM670 using Android Central Forums
the keyboard thing happens to me on quattrimus also, and no it doesnt use the sd-ext by default, im not sure how to add that. ill see if i cant get it in on the next update.
updated op by recommending amphetimines. im trying to include them by default, but i need permission and it needs to work.. flashing works great though
Already done:D did that when I flashed with v2 which I do believe redbaron adjusted it for ics roms :p also should always be recommended
latest update isnt looking good... superuser keeps automatically denying everything even though its set to automatic allow.
Update: bt phone not working at all:( but music works with skipping songs:D installed apollo
Yes Bluetooth is probably broken. This from is using fairly old ice blobs. They need updated and that will take time.
Miserydhala
