[ROM][ALPHA][WIP][ICS]: CodenameAndroid
I couldn't wait so I flashed before work haha I go to work in 20 min I will report back after. So far amazing :D
Sent from my VM670 using Tapatalk 2
Reactions: sellers86
I cant restore apps from Titanium back up nor from the google store . I can only install from the apk. files i downloaded onto my sd card
Okay thanks for the advide.. just one more question , i always set my cpu to 600-728 , but one this rom i guess its lagging it because it jitters sometimes...idk what it is , i didnt mess with anything else in the performace section because i really dont know much about the tweaks and other stuff , just cpu
I can't recreate the issue. What do you mean by jittering?
Tips if your a s user
Don't flash different kernel
Download apex
CPU settings to 768 Max 286 min
Change buttons with app over at xda
Change virgin mobile to sprint
Mess around with tweaks
Looking for good cm9 or cm7 themes??? visit this site for good themes. http://forum.digitalhouseoftreats.com/
Jittering as in um .. when i see a picture the picture flashes like 4x then stays normal . idk but umm is the camera suppose to work yet? cause mines dont, im just saying -.-
Not sure about the jitters. And the camera prob is in the op
Lock screen didn't work once wouldn't let me unlock. So I had to reboot. And there's no music player???
Man, I always forget about that :p. And by lock screen not working, do you mean it was split? If that's the case, lock and unlock the phone. And would you happen to have an sd-ext partition?
Reactions: topdawg661
Report: same spilt screen boot issue as Bobz and Johnnys roms (fix is the same press power button after boot is done) I've been running for a couple of hours now @600/480 interactive no rr :D, tb works fine to reinstall apps ( sellers I know with tdms ics it uses the SD next partion to install apps automatically just wondering if you were planning to add that feature on cna not a big issue just curious don't mind using tb) standard lock screen works just fine , that's about it for now for what I've really messed with I'll be back later with a update. Aside that yo looking real nice great work bro :thumbup::thumbup::D:D
Sent from my VM670 using Android Central Forums
I'm 95% sure the split screen is something in bobs device and vendor blobs. And its caused by having a sd-ext partition. And I'd gladly add the script if I knew how. :p. I'll talk to tdm about that, may be in a coming update. I'll update tomorrow and add apollo. Glad it works for you though :D
Reactions: inceyet
I love it even more then the first day you posted it! Great rom man!(:
Miserydhala
