[ROM] Android Open Kang Project
so is it GPS that's busted in 39, or 4square?
i dont use it, but need to know my maps/nav will work
GPS works in build 39 but locks much slower than in prior builds. I used to get a lock in less than a minute and now it takes at least 5-10 minutes to get a lock. May restore a build 38 nandroid and see if that makes a difference.
Sent using Tapatalk 2
Latest Franco kernel 192 features 1651 mhz OC.
Needless to say, my nexus didn't like that setting. I had some random freezes and restarts.
I ran it for an hour but did nothing of substance.
GPS just locked on here in about 12 seconds, Fwiw.
Yeah, mine locks in pretty quickly also on build 39 using franco nightly 190, not sure what the cause of the problems for others is. Only time I had an issue was using linaro build.
I'd guess more often than not they didn't wipe when they flashed, restored bad data, are victim's of coincidence and just got some slow locks in a bad area or at a bad time, are exaggerating the issue (not on purpose probably, but still) .. Or some combination of all those possibilities :)
As is the case when you experience bugs that most other people are not, it's usually, logically, something you did.
EDIT: just tested again for the heck of it and it locked on in like 6 seconds..
Probably all pretty logical reasons, I know I came from a different ROM so I wiped which could be why I'm having no problems, I checked mine a few times and every app locked in within a few seconds.
I've tried 14xx and currently on 13xxMHz, really don't see much over 12xxMHz where I usally stay at. I do like the new 576MHz though. Love AOKP and Franco combo!
Did a full wipe, restored data, didn't work. did full wipe, downloaded app, still no go. I am in a fringe 4g area though.
Yeah, my phone is getting redonculously hot with the new nightly kernel 192 Franco. Phone will restart on high cpu usage like GPS.
cinemacritic
