[ROM] Android Open Kang Project
I may do a full cleanse. Can't get foursquare to work at all with 39. I mean at all. I did a fresh install of the app too.
Like I said before a lot of people are complaining about foursquare recently on aokp and cm9 (and perhaps other roms as well, that's all I really pay attention to though).. so it's likely something on four square's end. I'd check around the threads and see if it's just you before going through the work of doing a full wipe with the sd too, etc when that might not even fix it.
Alas.....may have to go back to 38...need me my free coffee from foursquare. it seems to be a v39 build issue and not just me....bummed :( I tweeted it.
Back on 38 and not even using Franco yet. all apps work...I bad mouth 38 and now I rely on it for my caffeine fix....go figure. Apparently Roman is aware of the fact they accidently used cm7 and not faux kernel and that seems to be the problem. Dunno if a quick fix #40 will come out but we shall see I guess.
Side note:
Anyone running the aokp backup app?
Side note:
Lol so you could have just flashed kernel?
i want to throw my phone from the 10th floor terrace.... why am i the only one with inexplicable connectivity issues?!?!?! B37, franco r190 - as soon as i turn 4G on, it works for a few minutes, then either switches over to 3G, or shows bars, but i have no connection. this is a huge W T F
Probably cuz you're in a weak 4g area.
doubt that - i am in midtown NYC, and as i mentioned a few posts back, the guy sitting next to me has a completely stock/locked/unrooted LTE Gnex, and doesnt have these issues.
at the same time, i cant figure out what else can be the problem
Faulty hardware..?
hmm, maybe not.
i just did a side-by-side test with his phone. its even worse than mine, so i guess it really is weak 4G in my area.
I'd presume in 1-2 weeks, depending on their satisfaction level with newer features.
siratguidance56
