[ROM] Android Open Kang Project
Nothing in the Twittersphere, but it looks like it isn't code-related, according to an earlier post. Hm...
Meh, I should go back to bed in that case. I don't care for the wares they're peddling unless they're code!
So I'm still on B36 and thinking about updating to the latest. First update for since rooting.
Just Nandroid, download latest build and GApps to SD card, check MD5s, wipe data and factory reset, flash ROM and Gapps and I'm good to go (obviously restore everything with the latest Titanium Backup run once up and running)?
just dont restore data in titbu.apps only. But, to be honest gapps does most of the restoring. I don't use titbu anymore.
I usually restore app data, but my phone doesn't like it this time. Nothing terrible, just a force close or two a day... although it could be from AOKP backup. This was the first time I used it. If it gets worse, I'll reflash and not restore using tibu or AOKP backup. Thus far, it's not enough to really bother me... and it's mostly ROM control that stops working. Certain widgets in the nav bar don't work.
I know a fellow member who does the same and who also encountered some issues with doing that for this build...where's 2def?!
Hi.
I restore a ton of app data. As long as it's not gapp data and of course no system data its usually fine.. However this go I'm having an issue with swiftkey 3 but that's it.
Hi.
lol good morning. Just another reason to try Swype...
anyone try franco r196? i flashed via update tool, my phone started resetting, even with M4 on, so guessing its the tool not the release? who knows. had to go to stable leankernel to get the phone back to normal
I've always restored my application and data for every build and the only issue I ever have is with both Apex and Nova launcher. The issue started around build 36 if I'm remembering right. And what happens is the widgets stop updating/working and the fix is to kill the launcher. After killing the launcher all is good for anywhere between a few hours to a few days.
Reactions: zero neck
I've been on r196 since it was released with absolutely no issues here.
I'm also on a different rom, so...
I'd say don't restore the launcher data with tibu, you don't need to anyway since they back up and restore their settings and desktop data for you on their own.
Swiftkey is too good.. I refuse your offer :p
Swiftkey used to be my favorite, but the latest Swype beta really blows all the other keyboards away...
Part of that is because it allows for customization via Facebook, Twitter, Gmail, and texts, just like Swiftkey.
See! What'd I tell ya?!
vdacau
