[ROM] ApeX for Droid X - An AOSP Experience
Another question are the resizeable widgets only with the leak version of apex or is there a setting for the 1.0.2.2 version also?
I have not tried them but believe they work. I killed the launcher that it came with for launcherpro and in that u can't.
Sent from my DROIDX using Tapatalk
When I was trying to install the theme I got some weird thing going on like it didn't fully take. I was trying to put on the revolution theme but I don't have the paid version of rom manager. So I was trying to install it the same way I did the rom through recovery. Has anyone had luck doing it this way?
If u dl the zip and put on sd card u can apply with rom manager or bootstrapper applying zip from sd card. Did u uninstall market update and google .
TNT question for ya... I have been running the new apex for about 2 days now and even installed the new revo theme for it, but recently, started this morning that I noticed. When I go in to handscent it opens really really really slowly, but does come up.
Not sure if it has to do something with the rom?
Not sure about that. I don't use it. Does a reboot fix it.
Yeah weird. Still a bit slow in opening the actual program, but that's the only program that is slow opening all the others are fine. Maybe it's not because of the rom.
Hmmm oh well?
No I don't think I did, do I need to leave them permanently downgraded or just install revo first and then upgrade later?
Need to open both and uninstall the updates before you theme.
Got the revolution theme to work but the sliders in the front look weird now. Anyway to get the sliders back to the froyo ones?
Yea not a fan of them sliders. First thing I changed. Then rethemed a bunch more of it.
Just want to say thanks for all the help and putting up with the lame questions lol. First time I rooted my phone a while back bricked it big time, fixed it but was scared to death to do it again. Now im back and loving it trying to see what I can do now that I've paid alot more attention. Anyway im rambling thanks again, more questions coming later.
Has anyone tried the new "Next" theme for apex? How does it compare to the earlier version for the 1.0 version of Apex?
I used it its more done up with color and stuff than revolution. The themes from 1.0 and now are the same. Just updated to work with he new update.
I feel real silly asking such and easy question, but I can't find the answer.
I want to use the NexTheme but "Please uninstall Ringer Toggle Widget and Moto Torch". How the heck do you do that? Just rename?? Where do you find Widgets with Root Explorer?????
Please don't flame me to hard. Thanks!
Lol y just don't use them. They are extras and if you don't apply them u don't use them. Dl the theme and go into it and delete them. Should be in the system app folder. Not 100% since im not running it at the moment.
Reactions: TVCMI
lmao, Of course! Thanks tnt! I have both on my phone right now and was trying to figure out how to get rid of them. Duh! You are very kind!
reblkari666
