[ROM] ApeX for Droid X - An AOSP Experience
What's the difference between 1.1 and these other ones?
I'm running 1.1
Sent from my DROIDX using Tapatalk
Anyone know how to get the multi touch key board to work with apex. Keep making errors typing. I tried to push the stock LatinIME.apk file but it wont install.
Would you suggest me installing 1.2.1?
Do I need to do anything special? It says for users running leaked 2.3...
I'm running 2.2.1 for the os.
If your running the 2.2.1 leak you have to run apex 1.2.1. Your phone is no longer the ota 2.3.15 it is leak 2.3.320.
REVO theme is up for the new version in rom manager and in his posts. Follow instructions as you need to do a few things before you apply.
You beat me to it....looks awesome tnt.
Im going to retheme some of it blue and will drop some screen caps and a zip in a few days. Will be REVOlutionBLU.
I guess you do...I just tried it straight from romanager and it put me in sbf
bootloader...yikes
Lol that sucks. I said you have to do a few things first! Hope its not that hard to correct.
Anybody know how to uninstall updates to Market and Google search?
I got lucky...all good. Just pressed the power button. It rebooted normally.
Open settings. Applications. Manage. All. Click app and click uninstall
Still wouldn't take...I had to manually go in bootdtrap and do it Old G. Thanks for the heads up TNT. check me out!
Nice layout! Going to rock that wallpaper too. Wish my overclock had a widget.
Quick question, I'm currently running the apex 1.0.2.2 rom and I want to run the revolution theme, do I need to install it the same way i did the rom through rom manager or is there a different way? thanks for your time.
Rom manager works fine. Just dl the new one. Follow instructions I posted a few back and your good.
Working on a theme in a theme. Got some done tonight and hope to have rest done by the weekend. If you like blue you might want it. Trying to load a screen cap but system is being dumb.
fusionrobes
