[ROM] CleanROM DE 1.4by Newboyx 8/16/12
I use UCCW (Ultimate Custom Clock Widget), to display weather, but it won't update. This led me to discover that stock Sense weather has been removed in CleanROM, which might be the cause of the problem, if that widget is looking for data from the stock weather service.
Can't seem to find any flashable zips to reinstall sense weather. Thoughts?
-Tom
-Tom
You can install any weather app from the Play Store to accomplish the same thing.
Sent from my EVO using Tapatalk 2
Reactions: TomTomHatesCats
Thanks for the reply!
The strange thing is I already have WeatherBug installed, but UCCW doesn't seem to use it for data (UCCW has never updated since I flashed the new CleanROM and installed UCCW and WeatherBug). I'm wondering if UCCW is designed to piggyback directly off stock weather?
Since UCCW is pretty popular for customizing the look of our devices, I wonder if anyone else here is experiencing this issue, if it's ROM-related.
Also, sense weather just looks good, so it would be nice to have the option to use it :/
-Tom
-Tom
When I get the time (I have to borrow my wife's laptop anytime I work on this, mine lost a battle with gravity) I plan on making a few different add ons that will be flashable.
Also, can you link me to the app in question, I would like to test it out.
The developer got back to me:
"Uccw gets weather data from Google as its free. In future more weather data providers may be added."
So, for now, it looks like Google's weather service needs to be active on any ROM for UCCW to run properly. I'm now wondering how many weather apps are just skins that actually piggy-back off Google's weather service to get their data.
-Tom
-Tom
Did you use 1.1 of my ROM? If so, did the weather work on it? I think the app polls weather data regardless of what weather service is installed on the phone. Sense weather for example uses Accuweather, not Google, so removing it should have zero effect on the app getting data from Google.
When I flashed CleanROM 1.1 originally, I hadn't yet installed UCCW, so not sure if it would've worked. I was using WeatherBug on 1.1, which worked fine. I'll nandroid my current setup and test it out later today.
-Tom
I'm a moron. Flashed 1.1, installed UCCW and dropped in a weather widget, first showed up as generic text, but set weather settings to auto-locate, and voila, it worked.
Restored my 1.4 backup, did the same thing. It works fine. All is well!
-Tom
-Tom
Ha!
Glad you got it working.
How can I get adaway to work with this Rom it can't write to the hosts file worked on stock rooted but not this Rom :(
I will look into it eventually, but honestly it's not a very high priority. Most independent app developers only get paid by displaying ads. By blocking ads from displaying you are basically stealing the app. Independent developers spend a lot of time working on apps for us to use, taking away their source of income is not cool.
Anyway to turn off the camera button from starting phone notice it turns on while in my pocket. Will like to disable it but cannot find it in settings.
Sent from my EVO using Android Central Forums
That is not a user accessible setting.
websitedesig101
