[ROM] Codename Android
Right off the back it didn't do the Android start up screen, didn't have screenshot or reboot options... didn't look any deeper. I downloaded twice and loaded each download. Dunno.
Interesting, mine had the start up screen. did you go into general setting and check it to show screen shot and reboot? it looks to me like the are default off now. I checked these and and now have screen shot and reboot as an option.
This ^^. All that stuff is in the OP on XDA if you read it...just sayin'
Pulled this from the OP at XDA...
Feature List/Changelog for 1.4.0
CHANGELOG
### 1.4.0
* YOU MUST FLASH GApps since it is no longer included in ROM
* DO NOT USE THEMES OR MODS MADE FOR ANY OTHER VERSION. ONLY USER THEMES OR MODS MADE FOR 1.4.0
*YOU MUST DO A FULL WIPE. Wipe cache & data/factory reset
*Report bugs only after you confirm bug by having nothing else installed besides ROM and GApps. Use the BUG TRACKER.
* common: CNASettings has been merged into settings and has been completely re-writen to work better on both phones and tablets
* common: removed google apps from compile
* common: added the file manager back
* common: wait to lock screen (romanbb)
* common: webos style recents (Zaphod-Beeblebrox)
* common: better rotation control options (Team Eos)
* common: Added CombinedBar Auto Hide (Flemmard)
* common: all lockscreen graphics have been improved and resized (androiduser)
* common: root is now option (cyanogen - in developer options)
* common: faster transition animations in the launcher (nebkat)
* common: Hiding media from folder with .nomedia file. (cyanogen)
* common: all battery and clock customizations now work on tablets
* common: enabled the Notification Power Widget Enable on tablets (TDR)
* common: improved scrolling chache for much smoother scrolling (pawitp)
* common: zRam and Kernel samepage merging (cm - performance -> memory management)
* common: option for always enabling battery percentage on the lock screen (whitehawkx)
* common: improvements made to the lockscreen to work better on both phones and tablets (codenamedroid)
* common: phone target is now replaced with browser when compiled for tablets
* common: camera unlock target is now always accross from the unlock target to emulate the stock android lockscreen layout
* common: Increase Zygote preload GC threshold to half the heapgrowthlimit for faster boot times (Vijay Dandiga)
* common: fully configurable power menu (romanbb for screenshot and codenamedroid for reboot and airplainemode - Interface -> General)
reboot and screenshot options disabled by default to be more in line with stock
* common: made clock on big clock a tab bit smaller: looks nicer and works better on phones with smaller screens
* common: Profiles - Quiet Hours - gives the ability to have certain sounds, vibrations, and notifications to mute a specific times (DvTonder)
* common: fast torch - enable flash light from lockscreen by holding down on the power button while the screen is off (Zaphod-Beeblebrox - Interface -> Lockscreen)
Meh, reading is overrated lol. I must be missing it?
LOL, I knew you were going to say that.... The release notes are so long it takes almost as long to read and just "flash and see" :)
CHANGELOG
### 1.4.0
kctraci1
