[ROM][CyanogenMod9/AOKP][WIP][THEMED]VanillaBean
Status
Not open for further replies.
No, not really. I don't have much of a life to be honest. I spend my days mostly moderating an MC server I play on, playing Battlefield/Fallout, Using 3DS Max to model/animate, or messing around with some APKs and stuff.
Aside from that, There are two major things that I can't get right in this ROM so far which are literally tearing me apart 24/7. I have no idea where one of them leads to- an XML that references things not found in SysUI or FrameRes, and a bloody SetupWizard which FCs every time I start the ROM up so I have to rebuild it up from Quattrimus, which isn't all together hard to do, but annoying as hell. Also, voice search takes up 5mbs of the ROM size which is ALOT to the point that I wonder if it's worth it for a not-very-needed feature.
All in all it's so annoying that it's almost discouraging to work with this as I know it's all I have until i magically find 350 dollars on the floor to buy a GNexus :P
Reactions: topdawg661
In all honestly what your doing is amazing in itself. I wish I could learn to code android ROMs, i only have Java coding knowledge. Its your rom, you release when you need to. Dont be pressured okay? We like quick releases but not if its going to drive you nuts. Do what you need and if you feel like some moral support pm me. =] Your rom is good, slow down and relax, you will find the location of the files eventually.
Hows things? Lol. I know, I know. Patience is a virtue.
Yeah, I guess I have been slacking off, partially considering we really have JB now. I mean actually JB, not themed ICS :P I guess I'll pull something together when I come back today and call it finished.
we have a truly functional jb? What did i miss?
Is this ROM dead?
I really like it but it gets really hot when charging and has horrible battery life.
Savage min 320 max 729
Is this ROM dead?
For a rom to be dead, it has to be about 4+ months.
If you can't deal with battery, I suggest IHO, like I use. ICS is still early developing.
IHO is not an option.
It's just this rom specifically, not ICS.
Early developing? ICS is in beta now.
No, ICS is fairly stable these days. With my dad's promise of a GNex in early September and several actual JB roms out, I've lost my interest in continuing this unless any of you want to do so. I'll still keep this one plugged into my home wifi
Like Bob said, CM is basically slowing down on CM9, while those developing is still trying to get things running. It took IHO a year, almost.
Status
Nazeer zaheen
