[ROM][CyanogenMod9/AOKP][WIP][THEMED]VanillaBean
Status
Not open for further replies.
I know why the Email doesn't work, Ill get the fix in. I deleted an application called Exchange since it seemed to always malfunction for some reason. I'll put it back in and @ USB, it works. Even for me with a faulty cable I can connect to my PC via UMS.
About the market, what does it do? Just FC?
Edit: The Google Now thing is the same exact one that I have in the ROM, except they added Voice search. Will update in V7.
Reactions: joerivera17
I hope to flash this once most of the kinks have been worked out :) good job, this helps ease my envy of those with JB ROMs
Not there at all checked in the system/app folders there's phonesky.apk permissions set right check in drawer no market
Looking for good cm9 or cm7 themes??? visit this site for good themes. http://forum.digitalhouseoftreats.com/
Im not sure then. My play store works. DOes it show up in your apps? Try getting it from somewhere and putting it in. Or try reflashing. Youre also on the LG Optimus S i beleive so I can't say that I'll be providing support, as this was meant for the V.
I will test when u release v7 as u mention earlier. It looks like is going to be awesome. Not rushing you, take your time. :D
Looks like Google pulled it (sneaky bastards). I'm pretty sure you can find it on xda-developers somewhere.
This rom gave me nothing but problems, multiple galleries and cameras, search force closed, random reboots. Still I'm keeping an eye on this cause at some point is like to run it
From your screenshot you have only one Gallery. The second camera is because the JB Gallery has a Camera. I'll remove it and make sure it has only one camera. As for Google Search/Google Now, it is still a Jellybean port which is semi-stable and I beleive was originally meant for AOSP roms, not CM9 roms. If I figure out a concrete way to solve this I'll be damned sure to fix it. It seems that for some it FCs and for others it doesn't.
Mcclain.... ffs.... Anyone who watches Quattrimus knows that it's a kernel based problem....
ALSO, =CAUTION= =ATTENTION=
ANYONT HAVING ISSUES WITH GOOGLE NOW FC'S, GO TO YOUR APPS AND CLEAR THE DATA. WHEN IT ASKES YOU IF YOU WANT TO JOIN/USE THE GOOGLE NOW THING, DECLINE IT AND IT WILL WORK. IF YOU ACCEPT IT WILL FC LIKE A SON OF A YOUKNOWWHAT,
=ATTENTION= =CAUTION=
Sorry about the lack of updates.
As of recently, AC on this computer is looking a bit "wacky" and I haven't had much time to work on anything, but Version 7 is in the making and is very well on its way.
I come back home on the 30th and when I do, I'll have more time to do some final fixes and then I'll release it/
Status
sikhanegi
