[ROM][EPIC 4G][CM9] CM9: CyanogenMod v 9.1.0 -Stable
Re: [ROM][EPIC 4G][CM9] CM9: CyanogenMod v 9.0.0-BETA-2
screenshot 'androidian' theme for CM9_beta3-pre9:
I am running CM9 Pre3 pre9 I want to use the wifi hotspot with my nook color and was wondering if I just use the built in one or if I need an app. I just do not want to see charges from sprint.
You won't see charges.
Sent from my SPH-D700 using Tapatalk 2
Not sure why, but I my Facebook contacts are not syncing in to my contact list. Running CM9 Beta3 Pre9. I've tried turning sync off and back on a few times to see if it would eventually sync, rebooting, uninstalling facebook and reinstalling. Not sure.
Bug maybe?:-\
I had the ability to set the keyboard and capacitive buttons to time out the same time as the screen with gingerbread. Now that I've updated to CM9 the screen turns off after a minute but the keyboard/capacitive buttons turn off after a few seconds. I know this saves some battery life and I should adapt to it but if I want to keep it the style it was in Gingerbread, how do I do it?
CM9_Beta3 is HERE!!!..............do read + follow the Release Notes for your closest near-zero-margin-of-error version on CM9 ever!......THNX Epic CM Team, your thoroughness in getting a good solid Beta3 is just awesome!!!
http://epiccm.blogspot.com/2012/05/cm9-beta3-for-epic-4g-release-notes.html
Install Guide is HERE:
Cyanogenmod Epic 4G: Goals for CM9 beta3 for Epic 4G
a place w/ themes, now's the theme engine has been set free!
Official CM9/AOKP Themes Thread - xda-developers
*ninja edit: OK........FYI: Candidate1 appears to be the same as Beta3, if you've already installed you're good to go! .........here's the md5sum so that you may match your file against the Install Guide: CM9_beta3 md5sum 02e0d22b5da67830f48b2491dc51d524 .........Enjoy!
AHHH YEAHHH!! To be honest, ICS has been running great for me. No problems or hickups whatsoever. Good to know that its being perfected even more!
nice.
I tried getting the theme posted on G+ yesterday and got an "incompatible device" prompt on the play store.
Is there an apk you can post or do I need to wait till the next build gets released?
Try DL'ing your theme direct from the CM9/AOKP Theme thread (link is several posts up), then install to system using your file manager, + then load it using the Theme chooser from settings; DL from Play Store should install, then you'd only have to load theme fr Theme chooser.......the Play Store is not quite stocked yet, but it's getting there! ;)
Sent from my SPH-D700 using Android Central Forums
Reactions: HAAS599
I know the Shadow kernel is supposed to be updated now that beta 3 has been released but does anyone know if the last updated version of Shadow will work as well?
The most recent version of ShadowKernel, v.0.6.1 (3/20/12), came before beta3-pre3, so it's not recommended for beta3 (shadowKernel version for B3, not here yet).............recently Bbelos (author of Shadow) has been gaining ground while working on getting the Epic 4G 3.0.x kernel off the ground; here's the update:
Cyanogenmod Epic 4G: Epic 4G Kernel 3.0.x Progress
.....it may be worth waiting for the test version of this: no ETA's, but coming soon, as evidenced by the link-holder on the progress report :)
Reactions: The Harrington
Thanks for the info sonarchist. Will wait for the updated version.
hello, i cannot seem to access wifi at home ever since i got the cm9 beta 3. it is keep saying authentication problem. anybody know what is wrong?
I have a question. When I get a media message that I can play , the screen just flashes. Also is there a WIFI hotspot that I can use for free WIFI on CM9?
All I had to do was re-enter the password for my network when I went from beta2 to beta3.
As not everyone running CM9 is also using Google Voice, + as it has been asked with some frequency over the course of time on this thread, I am pleased to be taking a moment to mention that the recently posted Sprint Visual Voice-mail zip for Android 4.0.4 / ICS is available for DL over at the AOKP Epic4G Blogspot .......... this newer version of Sprint VVM works perfectly fine w/ CM9beta3: been running it since this past Saturday w/ no hiccups whatsoever + just know that this will be a handy fix for those that prefer an alternative to GV.
AOKP Epic 4G
Please remember to Thank Alias8818 (Epic CM Team) for providing the DL link on his AOKP Epic 4G Blogspot!
AregbesolaOmot1
