Officerpolabear
- Jan 16, 2011
- 893
- 52
- 0
It worked!!
Yup, but keep in mind if it starts to make the whistle again, all you gotta do is manually reboot the phone and it fixes it again.
It worked!!
My phone does not ring. Has anyone figured out how to get it to do so?
Did you try the 10/15 update? that fixed the phone ringing issue, but caused some people to have wifi connectivity issues.
enjoying the CM7 experience on my epic but what's the deal with the no 4g???
The 10/15 update is the only one I have installed and I flashed it fresh from stock EC05. I was having connectivity issues before I updated libaudio.so, now the phone rings and I still have wifi connectivity issues.
Whats with ClockworkMod Recovery. I understand that if I have it installed, I can get the nightly updates from CM7 but I am not steered to the correct version. I don't want to install the version for the i9000 but that is what ROM manager is telling me to do. Anyone know what to do?
ROM manager doesn't work for the Epic so you should stay away from it. I think the reason why it's on the ROM even though it doesn't work is because ROM manager is included in CM by default.
Should I delete it?
Since, it isn't running in the background, it doesn't matter if you delete or not.
Is it something that I might need down the road?
I guess I have my answer. Please note guys, you must delete it through the Market. That is the only way.
Can someone explain the benefit of flashing the 10/15 update? It sounds complicated and it seems like you lose more than you gain.
