[ROM][FF18][July 01, 2012] DK_Liquid_Ice_v1.2.0_Stable
Status
Not open for further replies.
Re: [ROM][FF18][June 29, 2012] DK_Liquid_Ice_v1.0.1_Stable
same way you installed the rom the first time: download the zip file to you phone or sd card>> put your phone in CWM>> clear both cache and dalvik>>aply update from sd or from wherever you may have it!
Both issues or just the voicemail issue
Sent from my SPH-D710 using Android Central Forums
Both issues.. you have to go on Google.com/voice from your computer to get rid of the press 1 to answer feature.. I had the same problem and Google voice just annoyed me.. so I deleted it..
I just tried the patch.. I forgot to wipe the dalvik and cache.. but then I rebooted a second time wiped and reinstalled but my Bluetooth still isn't working.. can I fix it?
I have been running this ROM since last night. I must say this is a fine piece of work. Many thanks for sharing it with the community!
I do have a question, if I may. I noticed two mods and a kernel in separate threads: DK_Liquid_Ice_Tweaks, Dark_Knight's_GPS_Fix, and DK_Liquid_Ice_Kernel. It seems clear from reading the "What is" section that the tweaks are included, but wasn't sure about the other two.
Thanks again and keep up the fine work.
Yes every piece is included in this rom. Tweaks. Kernel. Gps. And theme.
Sent From A Rotary Phone
Try fixing permissions inside rom manager app. Then rewipe dalvik.
Actually stand by I am making a new patch to address the bluetooth again. This time it will be fixed.
Re: [ROM][FF18][June 29, 2012] DK_Liquid_Ice_v1.1.0_Stable
New Patch v1.1.0. This refixes the bluetooth issue. Enjoy. I swear its fixed this time. :)
Download Patch Here:
http://db.tt/vKR9iqNA
hmm, wiped the caches and installed this patch. still can't turn on bluetooth.
awaiting a fix, but enjoying the rest of the ROM, thanks!
It works on my end. It has been fixed.
can you offer any suggestions to get my bluetooth working after patching? i'm willing to start from scratch again if needed
Go into settings....applications......bluetooth and clear app cache and app data. Boot into recovery. Wipe cache and dalvik cache. Flash patch. Everything should work after those steps.
assuming you meant 'bluetooth share', it was only bluetooth app i could find under applications. it was grayed out for the ability to clear data and clear cache.
booted into recovery, wiped cache and dalvik, repatched.
still wont let me turn on bluetooth. it attempts for about 20 seconds and then turns off.
i'll wait and see if i'm the only one with this issue. probably do a full wipe if thats the case. thanks!
Just tried my Bluetooth. Tries to turn on for a bit and then gives up.
Reflashed the patch. Still unable to turn on Bluetooth....
Status
Winnix
