[ROM] [GB] SmartViper
Sorry, but when I used danny's it installed...
I just looked at it, it didn't work because his update script uses edify which isn't supported much anymore. The Connect CWM supports it, but not the newer Viper CWM.
Sent from my SPH-D710 using Tapatalk 2
Yes the recovery can be written to have support for both edify and amend scripting, really any good recovery would have support for both. It involves editing the recovery, from what I hear its fairly simple but I don't know how to work with boot.imgs/ recovery.imgs.
Sent from my LG-LS855 using Android Central Forums
Gotcha, I'm editing my source code now. :)
ok im here my dad turned the internet off last night. also I could convert to amend if it would be eaiser i just chose edify cuz it has the print function
Just tried flashing it as a test for my TWRP build. It's extremely laggy, the only thing that seems to be fine are the android menu and lock screen. I can send you my TWRP build if you want to see for yourself.
@nigel missed you on irc :\
Edit:
Why does it only say "Toolbox!" when I run "reboot recovery" in shell :|?
ok I think its because it trying to download the ota update so its fixed in the next version. i will test and maybe upload if fixed.
Um when you flash 3.2???
danny, to prevent ota update prompts, just delete /etc/security/otacerts.zip. That's what tells the device what to search for on the server.
And /system/etc/security/otacerts.zip. Delete both of them , and you're good!
Just a question, if you know it breaks wifi, why keep it in there? I'm pretty sure people use wifi more than 3G and 4G.
Well when I first tried wifi it worked fine until this morning when I found out my wifi wouldn't turn on. It an easy fix just haven't had the time yet.
Sent from my LG-LS840 using Tapatalk 2
Do you have permission to include the alternative launcher from the devs? That's a big thing around here, even if it's free.
shadow03
