[ROM] [GB] SmartViper
Hey, when ever I try to theme it I get this rom uot.
Error log: UOT-12-16-09-31-1-SHTF.txt
Decompiling framework-res.apk UOT-12-16-09-31-1
I: Loading resource table...
I: Loaded.
I: Decoding AndroidManifest.xml with resources...
I: Decoding file-resources...
I: Decoding values */* XMLs...
I: Done.
I: Copying assets and libs...
Decompiling SystemUI.apk UOT-12-16-09-31-1
I: Framework installed to: /root/apktool/framework/1.apk
I: Baksmaling...
I: Loaded.
I: Loading resource table from file: /root/apktool/framework/1.apk
I: Loaded.
I: Done.
Compiling framework-res.apk UOT-12-16-09-31-1
W: Could not find sources
I: Building resources...
aapt: /lib/libz.so.1: no version information available (required by aapt)
/home/uotftp/port5/data/working_dir/UOT-12-16-09-31-1/fw_dec/res/values-ko/strings.xml:689: error: Multiple substitutions specified in non-positional format; did you mean to add the formatted="false" attribute?
/home/uotftp/port5/data/working_dir/UOT-12-16-09-31-1/fw_dec/res/values-ko/strings.xml:691: error: Unexpected end tag string
/home/uotftp/port5/data/working_dir/UOT-12-16-09-31-1/fw_dec/res/values-zh-rCN/strings.xml:689: error: Multiple substitutions specified in non-positional format; did you mean to add the formatted="false" attribute?
/home/uotftp/port5/data/working_dir/UOT-12-16-09-31-1/fw_dec/res/values-zh-rCN/strings.xml:691: error: Unexpected end tag string
Exception in thread "main" brut.androlib.AndrolibException: brut.common.BrutException: could not exec command: [aapt, p, --min-sdk-version, 10, --target-sdk-version, 10, -F, /tmp/APKTOOL3183032643807261266.tmp, -x, -S, /home/uotftp/port5/data/working_dir/UOT-12-16-09-31-1/fw_dec/res, -M, /home/uotftp/port5/data/working_dir/UOT-12-16-09-31-1/fw_dec/AndroidManifest.xml]
at brut.androlib.res.AndrolibResources.aaptPackage(AndrolibResources.java:255)
at brut.androlib.Androlib.buildResourcesFull(Androlib.java:324)
at brut.androlib.Androlib.buildResources(Androlib.java:269)
at brut.androlib.Androlib.build(Androlib.java:192)
at brut.androlib.Androlib.build(Androlib.java:174)
at brut.apktool.Main.cmdBuild(Main.java:188)
at brut.apktool.Main.main(Main.java:70)
Caused by: brut.common.BrutException: could not exec command: [aapt, p, --min-sdk-version, 10, --target-sdk-version, 10, -F, /tmp/APKTOOL3183032643807261266.tmp, -x, -S, /home/uotftp/port5/data/working_dir/UOT-12-16-09-31-1/fw_dec/res, -M, /home/uotftp/port5/data/working_dir/UOT-12-16-09-31-1/fw_dec/AndroidManifest.xml]
at brut.util.OS.exec(OS.java:83)
at brut.androlib.res.AndrolibResources.aaptPackage(AndrolibResources.java:253)
... 6 more
I: Loaded.
I: Done.
I: Baksmaling...
I: Loaded.
I: Loaded.
I: Done.
... 6 more
Don't know what went wrong looks like a server error where the files went missing in compile. So try again maybe with different settings like I said in the op some stuff will not work u will have to use common sense when enabling and choosing them.
Sent from my LG-LS840 using Tapatalk 2
I have an I tried just doing Battery for one Just doing font, and just doing boot animation and they all failed with that same error.
Really?? I just built a theme make sur you pull framework-res.apk from system/framework/ and SystemUI.apk from system/app/ in the rom package and before you send to kitchen make sur all the spaces are green
Ok so I installed the theme that I made and found out its missing a font and a drawble-hdpi folder in SystemUI.apk. So it boot loops. when I made maybe I didn't click hdpi but will try again and post my results
Fonts and boot animations can be done manually...
Sry bout not replying but as of now 3.9 doesn't boot I will take the themes out and then it will boot so I think we r going to have to theme manually. Also the lag issue is still present anybody have some advice for fixing it I'm pretty sure it's a permissions problem tho
Just to confirm with my suspicions. Danny does the system apps for the viper have the .pro extensions added onto certain image files? They make theming a nightmare.
Sent from my SPH-L710 using Tapatalk 2
Nope but some of them have 9.png. its just the pictures are not in the right places when using uot kitchen
Hey could I continue this? I've gotton used to Ubuntu and got a new computer with 4gb of ram 360 gb hard drive and quad core processer so it can now handle all of the crap and I've gotton Steam and Skype to work so I'm fine without Windows.
Next step: install a real Linux, like gentoo, arch, or slack
Sent from my DROID RAZR HD using Tapatalk 2
Infact, HEY NIGEL!!! Are you building 10.1 or 10? And where's the source files? I'm getting the repo set up for 10.1 right now.
Do u still want to continue this? It has no source files because I just copied it from the phone. But I could give u my working folder.
Sent from my LS670 using Tapatalk 2
dooleysdickulove
