[ROM][GB][WIP] CyanMobile Experience for the OV
Ok, I'm doing it on my Optimus, so I'm downloading a 7zip app by polar now
If your doing it on your phone it'll probably be easier to just use a root file manager to replace the file already on your phone in /system/etc
Tapatalk'n it from my Cold As Ice VM670 running LS670ZVJ firmware
Did not work for me, used apn from mirage...I will try from my PC when I get off work (as long as black ops2 isnt waiting for me!)
Probably because you didn't set the correct permissions. I'll upload a build with fixed mms tonight. I will also sync with cyanmobile.
Sent from my HTC One V using Android Central Forums
Rats... Still having trouble with getting SwiftKey working with sd-ext mounting on boot and wifi working
Yeah I forgot to switch the scripts. Update will have the different scripts, I believe the issue lies there.
I can't get airplane to toggle, from the widget or the settings menu. Other than that and the keyboard/wifi no problems.
That's odd. Let me check
EDIT: toggle works, setting doesn't for me. Weird.
Working good so far...not sure about ext though
So when on 3g, enabling airplane mode turns on wifi!
Wifi and 3g both work fine for me just thought it was odd
doxidex23
