[ROM][GB][WIP] CyanMobile Experience for the OV
Hey, the Wifi is not working, all I get is an error. And How do I change the lock screen? I can't find it.
EDIT: Found lockscreens, nvm. Still Wifi issues.
WiFi works... are you using a sdext partition? For lock screen, open settings>cyan mobile settings>interface (slide that grey bar up top, you'll see interface) it should be in there. If not keep sliding and look for lockscreen
Sent from my One V using Android Central Forums
Yes I am.
update will be out tonight or tomorrow with fixed bluetooth and possibly fixed wifi with sdext.
Yes. I used it multiple times when mediacom decided to shut down our WiFi (and almost everyones in town, it happens all too often). That's one thing I'm sure of.
Okay, well it's not working for me. I'm using the build without the theme...
This might take a bit longer than expected.. I have it compiling, I just forgot to commit some stuff before I lost everything, so I have some more work to do. Ill try to have a release out by tomorrow night though, no promises.
Yeah, not sure exactly what is going on, but I will probably flash something... not sure what, I do like your rom though Sellers, no offense! :)
Computer blew up again :/
Sent from my HTC One V using Android Central Forums
Bummer! I've attempted to build CyanMobile a few times but never completed. Mainly due to missing your vendor/lge and vendor/cyanogen/products and I'm not experienced enough to make iho's work for myself.
Tapatalk'n it from my VM670 running OM-Mandylion IHO on LS670ZVJ baseband
I had it building again, it isn't too bad. Couple of errors in frameworks/base. So it won't take me long to push an update when I get back up an running
Any news? I love this ROM but need bluetooth
Started it back up today. I'm busy tomorrow, but ill see if I can make time. I have the next few days off of work so ill have time this week.
Looking forward to it. I use Magpie now but would love this to work.
handsome
