[ROM][GB][WIP] CyanMobile Experience for the OV
I have flashed the CyanMobile for the LG Optimus V and would like know if it is it possible to disable the 'soft keys' (menu icon, home icon, search icon, etc) that are displayed below the dock icons? Any assistance would be appreciated.
Yes, the setting is under tablet tweaks, sorry I can't be more specific but it's there.
Tapatalk'n it from my Cold As Ice VM670 running LS670ZVJ firmware
Would not have thought to look there but I found it right where you said it was. Appreciate the quick response.
Trying to use the portable hotspot and unable to get connected. My laptop sees the SSID, however, it never does acquire an IP.
Downloaded Barnacle and was able to use it for a WiFi Hotspot. Is there something special to be done to use the native CyanMobile WiFi Hotspot?
Wish I could help but I never played with the hot spot on this rom
I have the WiFi Hotspot working with Barnacle so not a big deal. Would like to see the stock hotspot working eventually so I don't junk up my phone with duplicated apps.
Noticed the camera app works - until you try and do a video and then the camera app crashes and it takes a reboot to bring it back.
I can get video to work with a downloaded camera app from Google Play (UCam). Just would like the stock camera app to work.
Bump.... Is this still being worked on?......
Also netspeedz..... Notice the post date lmao
http://img.tapatalk.com/d/12/12/09/vuga5ezu.jpg
Lol nice catch. And yes, its being worked on, there just isn't much to work on. I need to find that post with the log cat of WiFi. Also, I've been busy with work, school, unbricking my one v, personal life issues. But no I'm not dropping this. Thanks for the concern :)
Sent from my PG86100 using Android Central Forums
Cool, no rush. I just would love to see the final bugs worked out of this. As it stands currently I still can't have SwiftKey+wifi+sd-ext working together. I can pick 2.... SwiftKey+wifi is fine or sd-ext+wifi is fine or I can sd-ext+SwiftKey. It's strange. Anyway just glad to hear your not dropping it, keep up the great work.
You bricked your new phone:mad:
That sucks...what were u doing
Sent from my HTC 3VO
Well not really bricked... I had no sdcard slot and no system installed, so it would boot. I ended up figuring out how to flash a ruu with fastboot.
:thumbup:
HTC does some funky stuff the first time you see it (especially comin from a one click ov!)
"sellers86" - have you given any thought to porting this terrific rom over to the LG Optimus Elite? We need some good roms for the Elite & yours works so good on the OV that I would love to put it on my new Elite...is it possible?
Sent from my LG-VM696 using Xparent Blue Tapatalk 2
Possible, yes. Will it happen? not likely, unless I were to get an elite. I am sure not buying it, Ive already got a Evo, One v, and optimus v.
So did mms ever get fixed on this ROM because I want to try it
Sent from my LG-VM670 using Xparent Cyan Tapatalk 2
Yes.... Check the 2nd or 3rd post. Btw, merry Christmas to all!
Sent from my HTCEVOV4G using Android Central Forums
heritagevine16
