[ROM][GB][WIP] CyanMobile Experience for the OV
How do I turn off the boot sound?
Idk if there is a setting for that. But to get rid of it, get a root explorer and go to /system/media and delete the .MP3 inside of it
Sent from my PG86100 using Android Central Forums
Thank you. Also, my Wi-Fi does not work. It stays at Obtaining IP Address constantly. Is this a known Problem?
Try going to /settings/Wireless and networks/WiFi settings. Delete the network.
Turn off phone. Turn off router and disconect from power source and modem. Wait 15 min for residual power to dissipate.
Connect router to modem then power. Turn on. Whn fully booted up turn on phone. When phone is totally booted up select the wireless network and input code.
Works with phones and laptops that can't be recognized by routers some times. Usually happens after switching networks that require a passcode and then coming home and trying to re-connect to home network.
Did you flash a,different kernel?
Sent from my HTCEVOV4G using Android Central Forums
Nope
I can't do that because it happens with every network I try to connect to and they're always public networks that I am unable to get to their router.
Nope
Did you try rebooting the phone?
Just a bump, and wondering if this rom was going to be continued?
Tapatalk'n it PAC-Rom style! Android 4.2.2 on my VM670 running LS670ZVJ firmware
It will be. Give me a few more days to work on ChaOS for my evo v, and ill work on getting a build out. Maybe sooner :)
I decided to revisit the last build. I still can't get swiftkey to play nice with it
I think that the WiFi/keyboards is the sdext stuff. When I get around to it, ill get an sdext partition and see what I can come up with
Right now I don't have the ext options turned on. And I deleted the init.d scripts that looked like they could have to do with ext
Hmm.. that's odd. I don't use swiftkey. Ill flash cyanmobile and see if it works for me
Sent from my HTC Evo 3D using Android Central Forums
Hmmm.
I feel the urge to flash something new.
How did this ROM excape my attention. Must try when updated.
Hmmm.
If you haven't tried it yet I'm sure you'll like it. I know I do... That's why I felt the need to bump this thread. :) also I got SwiftKey working after a fresh flash installed it first and a few reboots later finally got it to let me set it as default keyboard
Ti Emoti
