[ROM][GB][WIP] CyanMobile Experience for the OV
Also, the HoneyComb type lock screen doesn't work right at first, but I messed with the settings, I'll let you know when I get home tomorrow, got rid of the lag and the incorrect lock.
Yeah I mentioned this in the op, I would love to here how you fixed it up. I've been using the sense lock screen :p
At first the lock screen ring would go off the screen and wouldn't unlock.
I kept getting systemUI force close and messed with UI settings and changed something on the lock screen.
It does it occasionally, but it unlocks 80% better :)
I'll test again today. I'm on ICS and about to leave for the airport maybe I'll flash on the plane.
Reactions: sellers86
The sense lock screen and the slider lock screen run without issues
I forgot to mention, cyan mobile updates their git a lot, so if I update it may just be for a sync depending how long its been :)
Reactions: tvall
I've had a few issuse switching data to wifi, sometimes wont connect to wifi, other times it says it connects but the icon is gray, and I cannot connect to the web. Toggling a few times usually takes care of it but wondering if anyone else is having these issues. Maybe I should reflash???
Never had that problem...
Ok but I don't see it.. settings are too scattered.. how do I change my keyboard also
Network options are right beside wifi settings in the main settings menu. And since its gb, tap and hold on a text box and click input method
Wow! This is a daily, quick awesome looking lots of customization this is wooow! I ve only notice that mms is not working. Could some one please confirm this? Overall great work and thanks for sharing! :D
Just confirmed it. I'll try to get it fixed in the next build
Reactions: Badboytoast
mms wont send just stays at 'sending'
wish i would have realized at 12 when i originally sent it!
reflash seems to have helped my wifi issue
edit: oh yea, this is definitely my daily for now!!
Reported three posts up :)
Nammna
