[ROM][GB][WIP] CyanMobile Experience for the OV
I would be using the version from bobs repo, just because it has modifications made for our phone. But the statement was toward anyone in general. I think I'm going to do it, just because I like having the settings there too. The only thing I don't like is that its making this drift toward more of a CM rom. If I do it, it should be temporary. I haven't even had time to get a logcat of the FC.
Hey quick question... how do you change the vibrate settings for texts? cuz it just vibrates for like a minute straight even after I start replying, but usually stops if I hit the power button to lock the screen. But I know this is a known issue that the sms settings FCs so what should I do? Thanks btw awesome rom very smooth :)
help plz im a caveman trying to do and just cant grasp it. rooted ov already. [mod edit - removed phone number]
Rob, SMS is a known problem. The vibrating is actually a feature though. Its vibrating the message in Morse code I think
Why are the images distorted? Like in the screenshot. The bottom navbar looks smudges and where it says cyanmobile
Where'd you find that at?! I couldn't find Security at all? O:
settings>main settings>location and security
Unfortunately, the bug is confirmed... ugh. I really need help from an app coder... anthony, you busy? :p
Morse code?? If that's true, I think I may have to pull that into my rom!
Reactions: sellers86
Oh ok well hey I just wanna say this is a really awesome ROM! :D Def looking forward to whatever else you produce, you're totally awesome Sellers! :D and when you get sms settings will there be a different setting for the vibrate? It draws too much attention to me in class :X lol
yeah, it should have the normal cm settings. For a temp fix, im going to use cyanogenmods sms apk source, until I get the force close settled.
hulanpo1
