[ROM]GingerSnap 2.3.8 10/25/12| 2.2 Rebuilt to 2.3
Re: Need some serious help here
I'm unable to send large texts to others. Usually when you go over 1 txt block it will automatically go into two. However, my text doesnt get sent out at all and I have to cut part of it every time to send out my message. any fix for this?
Maybe the thread author needs to decompile the framework.jar in /system/framework (for both BASE and PORT) and go to com/internal/android/telephony/cdma and replace all the files with the ones from BASE.
Might help.
Anyone experiencing an issue in which you can't transfer files via USB? It works fine on stock, but both this ROM and Backside IHO don't register it.
Small glitch with some V's with some CM-7 ROM's.
Go to menu/settings/applications/development. Turn USB debugging on. Then as fast as you can, turn it off then back on.
Also: phone off, plugged into computer. Turn phone on.
Does anyone have the default wallpaper for this mod? It doesn't appear in the wallpaper list once changed and I really don't want to reflash and setup my phone just for that. :-!
Posting just to get to post 667 in this thread...
Tapatalk'n it PAC-Rom style! Android 4.2.2 on my VM670 running LS670ZVJ firmware
Not a real beast. Any beast mentioned in bible prophecy is a government or political organization controlled by Satan and his demons.
666 is symbolic of total and everlasting destruction. Really no need to fear the actual number as it appears in our day to day lives.
Re: [ROM]-GinerSnap 1.3|7-15-12|Stock LG UI!
nice rom
challenges: apps started responding well after about 3 restarts
phone model has changed from lg p500 to lg p690 ( there is no problem with dat)
doesnt support sim contacts phone only
overall u are the best man
another problem i hv encountered is that it frezes after lg logo when u flash the themes... need help!!!!
I remember this ROM having a cool feature where you could change screen brightness by sliding your thumb across the statusbar, does anyone know where I can find/use/install such a mod on another ROM?
MiRaGe
Bean_Whiz
Bean_Whiz? That appears to be an entire ROM, I'm currently using the latest gingerbread mirage ROM (ICS and Jelly seem to have a lot of issues/bugs still?) and I'd love to have a brightness slider in the notification drawer. is there a zip i can flash or an apk i can use to get this feature? Thanks
Bean_Whiz is my baby. Only bug is no speaker phone.
Wait till I post update with Toucan4267's cache script and Fly-OnMod tweaks.
I have 82 downloaded apps. Using Link2SD and Toucans script I still have 141MBs of internal storage still left.
Note: No app available that I know of to put brightness slider in ROM. It's a CyanogenMod tweak.
pramanj96
