Re: [ROM] Harmonia 1.5E (Aphrodite+Picasticks) 10AUG11 Edify FIxe
How on earth are you getting that much battery life? Can you say a little about your usage habits? I can't last even 12-14 hours even if I restrict myself to a few short calls a day plus some texting and social media stuff.
I've been running Harmonia 1.3.1 for the past month or so on my Optimus V that's about 3 months old. GPS/Wifi/Bluetooth are off always, other than if I use Nav or map a bike ride or something. Screen is always on dimmest setting.
I make sure I have as little as possible running. I don't load my phone up with a bunch of stuff. Once in a while I go through and see what programs are running and remove the highest use and look for more efficient ones. I run my screen around 30% brightness and I don't use any scripts to tweak any thing. Nor do I use any battery management.
I know people say "it doesn't matter what is in the background, if it;s not doing anything". BS. If I don't need it running in the background, it shouldn't be running there.
Personally, I don't see how some of you get so little.
This weekend I went on a long drive, I used Google Nav. for an hour, surfed the internet for 10 minutes, listened to music (some stream, some not) for 5 hours straight, talked on the phone for 20 minutes, and still had 15% battery. I repeated this on the way back. This was on an older IHO build, had it been Harmonia, I would have had 20-25% battery remaining. I used a 400/724 overclock with smartass settings.
As for my apps that run constantly, I have Widget Locker, and Beautiful Weather (updating every 30 minutes), I use Launcher Pro, no animated wallpaper (though that only changed battery life a small amount), and I use Easy Reminder (to tell me I missed a call). I never turn on bluetooth. Wifi I use on occasion, when i need faster rates.
I'm probably a light to medium user on most days, though.
Social media apps are where you are getting screwed. The biggest reason I rooted my phone at the start was to remove social media apps.
