If you download it for the Market, it is 11 megs. That is 11 megs of app space gone that early on was unable to move to SD. That has changed and now you can move most of it, which is why I haven't updated it.
By using the zip, it placed the 11 megs into the system area of the rom, saving you 11 megs for apps. It was a space saving measure.
At this point, you are better off downloading it and moving it to the SD.
Thanks for the advice. I went ahead and got it from the market. How does one move it to the SD card though? That option is grayed out.
Sent from my VM670 using Tapatalk
