Re: [ROM] Harmonia 1.6.1c (Aphrodite+Picasticks) 21Sept11
Thanks, that worked....wait a minute.... it worked once, but then trying it again brings the same results. Just an instant reboot, no asking if I want to go into airplane mode, reboot, recovery, etc. After trying a couple times, I can now get the power button problem solved consistently by re-installing the ROM, but after that I get the following issues:
I did a backup with Titanium Backup prior to the nandroid backup and re-installing the ROM. But, Titanium Backup was installed on the SD card, so it's not there after I re-installed the ROM. I went to the market using the internet/web browser - in an attempt to re-install Titanium backup, but the market thinks it's installed and wont' let me install it again. I also used the market on the phone, and it doesn't download it. It looks like it's starting to download Titanium backup, but it stops right away and it never gets installed. I've had this trouble with the Market before. Can't figure out what the problem is making Titanium Backup not get downloaded/installed. I tried downloading a couple different apps to see if it may have just been trouble with Titanium Backup, but they won't download/install either. I get the same result.
If I go restore the nandroid backup and get back to where I was before (power button not working, all my apps back, etc) and install an app off of the market, it works fine.
I'm beginning to be sorry I ever bought an Android phone.
Make a nandroid backup then without wiping re-install, you shouldn't lose anything, but should fix it.
