Thanks, I'll try that now
Edit; Flashed and works great . I didn't see in instructions in op for picasticks remix for new ovs. Thanks again. Really nice rom
That is from something else you installed.I think I've discovered something possibly broken. Under settings where you select a keyboard there is one called eyes free keyboard or something close.
I really like this rom by the way, great job!
You're welcome.I wish I had done this a long time ago, but I guess an advantage of showing up late to this party is that the code is mature and everything works perfectly!
So, thanks go to LeslieAnn and everyone else who's contributed to this ROM - you've done great work.
It already is.is there anyway someone can make this rom compatable with the new optimus v
Yes, it is.it is not
You just flashed the same kernel as the rom comes with. The only difference is that your phone took it this time.Thanks, I'll try that now
Exactly.You shouldn't have to but some of the new ov's have bad memory and the kernel doesn't stick, so you have to reflash it
Thanks!
Exactly.
I need to take a look at the install script and see if it can be improved, maybe there is a way to make it stick better.
I am unable to get 1.8 to start. I tried coming from 1.7 and from 2.05, and in both cases, it just reboots to recovery after the Harmonia logo. I tried the fix recovery boot loop option as well. Any suggestions?
I am running 1.8 with the V9 radio update, it is working great, I have much better coverage!
However this morning in my pocket I had the lockscreen unlocked and my pocketchanged the wallpaper on me. I'd like to get it back to the black & grey default (brambles background? don't know what you'd call it) but it doesn't show up in the stock wallpaper picker. How can I get it back? I searched, couldn't come up with the answer (just a lot of folks asking for the file itself).
Leslieann,
Thanks for the update. I am running 1.8 since I have done the V9 radio update and was getting the reboots while sending SMS. Once I did a clean install of the ROM, I could not get geolocation to work in either browser or beautiful widgets. I checked the setting in Location & Security and had a check next to "use wireless networks". Usually upon unchecking that setting and rechecking that setting, I would get a location consent popup. With your latest update I did not. I pulled the NetworkLocation.apk from the Harmonious Bumblebee Rom and replaced it in System/App, set permissions to rw-r-r and rebooted the phone. After going in and checking the setting in Location & Security, I now get the location consent popup and geolocation works in all my apps. Just thought I would let you know that it may be broken in the latest update, but it is easily fixable or maybe I am the only one running into the issue. Either way, thank you for the great Rom.
The default wallpaper acts weird because of how stripped down the rom is.However this morning in my pocket I had the lockscreen unlocked and my pocketchanged the wallpaper on me. I'd like to get it back to the black & grey default (brambles background? don't know what you'd call it) but it doesn't show up in the stock wallpaper picker. How can I get it back? I searched, couldn't come up with the answer (just a lot of folks asking for the file itself).
