Sean OGorman
- May 13, 2011
- 69
- 6
- 0
Re: [ROM] Harmonia 1.6.1c (Aphrodite+Picasticks) 21Sept11
Does it go back to recovery, or does it just stay black?
Hey, I've done a factory reset and formatted all my partitions (except sdcard) and I am getting a black screen on boot.
I think you have a 2nd Gen OV which has a Hitachi display. The 1st Gen OVs have Novatek displays. If you revert to Nandroid backup, download Harmonia with Picasticks Remixed kernel that has the Novatek drivers, flash that in recovery, and reboot, should show the display.
Another warning: the Picasticks remixed kernel overclocks the CPU by default. If ur phone has random forced reboots you will have to change the CPU settings.
I had to revert back to backside. I kept getting a ton of random reboots, even with installing setcpu and setting my CPU to 480/768. Any ideas what could cause it. My phone is stable on backside at 787
What I'm finding bizarre after 3 days of using 1.8 is that I was getting significantly better battery life from 2.05, which I used for the week prior to this. I reset battery stats when I installed 2.05 because I replaced the stock battery with an Anker. It just seems odd since I had more going on with 2.05 vs 1.8.
Could be an app that updated or you added, or even one that doesn't work as well on Froyo.
Is Harmonia 1.x close enough to stock to support the dialer codes mentioned here?
http://forums.androidcentral.com/virgin-mobile-optimus-v/164137-optimus-v-dialer-codes.html
I want to temporarily revert to a stock rom to use the dialer codes but I don't want to go back to actual stock.
Absolutely, all I did was remove the bloat and lag.![]()
LeslieAnn, will you be releasing Edify with 1.8? That would be absolutely wonderful!
Sent from my VM670 using Tapatalk 2
1.8 is Edify.
The last version with Amend was 1.4
I think I see what you are seeing.
The statusbars are 1.3+, but I say 1.5e is Edify.
I reworked the 1.3+ statusbars to be Edify and didn't state it on the downloads, sop the 1.3+ statusbars will work on any newer recovery and on any Harmonia 1.3 and newer.
Ok thank you where do I download or activate the black status bars? When I click on the status bar icons in your second post all I download is a jpg file. And I looked in the Settings menu for the Status bar tweaks, I could not find them.
If u could tell me how to get the black status bar, I would appreciate it. I tried on my own and I just dont know how to do it. Thank you for your help.
You can't download them on tapatalk, try using a computer and it will work, or of you don't have one, open up this thread in your browser and the links will work.
