[ROM] Harmonia 1.87 Froyo (Aphrodite+Picasticks) 12June12
I recently flashed 1.9, this is my first time rooting and using custom ROM
I was using link2sd and Titanium to reload all my apps and relink to sd
I did a fast reboot from within link2sd to free up some internal space and now my PIN doesn't work to unlock the phone
Any suggestions? I can still reboot and boot to recovery but I don't want to have to redo all the work I've done so far with restoring apps and linking to sd.
Nevermind - I reflashed
Factory reset is removed from this and when using a custom recovery, you should only EVER do it from recovery.
Gapps is included in this rom, but not all others.
If you went from Harmonia 1.x to 2.x or the other way around, you should have wiped everything and you should not restore system settings. The two roms have nothing in common.
Links to the roms will be corrected momentarily.
ahh crap i accidently uninstalled dialer with the link2sd app and had to re-flash harmonia.thank god i did a random backup a week before...was also wondering if there any possability of getting adobe flash player or is it like physically impassible.
Do a search for "armV6 flash"
You should find something that way.
I'm looking into trying this ROM. Just to be sure, the kernel in this ROM supports ext4, correct? I only ask as I want to be able to run my programs using link2sd, and my sd-ext partition is ext4 formatted.
TIA :)
Replacement Parts (Now in Edify unless specified!!!)
Things removed that you may want to put back
Unless specified, these are placed back in the system area, saving space for you to install other apps. Flash these through Recovery, but expect a slow first boot after. Be sure to boot into Harmonia at least once before flashing these.
Other Language Files
Sounds and ringtones
Alternate sounds (Same as above, but meant for you to extract to your SDcard instead)
Options!!!
Wallpaper
Stock Wallpaper
Stock Wallpaper in various colors
LauncherPro Dock files
Click to view quoted image
These are meant for use with LauncherPro, which is a free dock available in the Market.
LauncherPro Dock theme
The file includes Manup456's Clean (white) and dirty (black) Minimal Text icons, Orbz II center icon by H0CKEY, the bar (with button options). I included some variations of it. One has the bar higher or lower, another has shadows for each button. Another has a shadow for the bar. I don't claim credit for those other bits, I included them only for simplicity. The stainless bar and button options are mine however.
Statusbar Options: (These have been reworked as Edify)
Harmonia 1.3+ and Bumblebee 1.9+ ONLY, for older versions see below
Flash these through recovery, just like a rom. You can flash one on top of the other without wiping or anything but expect a slow boot the first time, just like when you flashed the rom.
Black status bars
[URL=http://img818.imageshack.us/img818/7527/blackwithstock.png]Click to view quoted image
[/URL]
[URL=http://img69.imageshack.us/img69/2126/blackwithsmallpercent.png]Click to view quoted image
[/URL]
[URL=http://img29.imageshack.us/img29/6376/blackwithlargepercent.png]Click to view quoted image
[/URL]
Gray status bars
[URL=http://img843.imageshack.us/img843/5272/graywithstock.png]Click to view quoted image
[/URL] (Flash this to return to stock)
[URL=http://img38.imageshack.us/img38/2559/graywithsmallpercent.png]Click to view quoted image
[/URL]
[URL=http://img846.imageshack.us/img846/7319/graywithlargepercent.png]Click to view quoted image
[/URL]
More Statusbars and Themes
Framirezferrer's black bars will also work on this rom.
As do http://forums.androidcentral.com/optimus-v-rooting-roms-hacks/103777-theme-custom-theme_team-themes-9-11-11-new-theme-mods.html
Older/other status bars (Harmonia 1.2 and earlier, Bumblebee 1.8 and earlier, all Aphrodite and Stock + Xionia)
(My thanks to Takenover83 for his help with these.)
(These are NOT Edify!)
Flash these through recovery, just like a rom. You can flash one on top of the other without wiping or anything but expect a slow boot the first time, just like when you flashed the rom..
Black status bars
[/URL]
[/URL]
[/URL]
Gray status bars
[/URL]
[/URL]
Changelog:
1.0 initial release 23Apr11
1.0.1 released 24Apr11 (removed)
1.1 released 26Apr11 wifi/Battery fix
1.1.1 patch released 26Apr11 fixes geolocation based force close.
1.2 released 6may11, MVDalvik, Init.D, and possible improvements to bluetooth.
1.3 released 17June11 TWS, reboot menu, updated a few programs, minor tweaks here and there.
1.3 Statusbars 18june11 Added Harmonia 1.3 statusbar options and corrected minor graphical bugs in them, added links to various other applicable guides.
Page layout 03July11 changed visual layout
1.3.1 16July11 Harmonia 1.3.1 Update added email and MMS from 2.2.2 and new Market app. Also new Maps v5.7
1.5 9aug11 Harmonia 1.5 released, changed installer to Edify for universal installation. gave up on the new market for now. Added new maps to options.
1.5E 10Aug11 Harmonia 1.5E Edify released with corrected V.15 Edify.
1.6 11Sept11 Harmonia 1.6 released correcting storage space issues.
1.6.1 21Sept11 Harmonia 1.6.1c released, correcting installer issues.
1.7 23Sept11 Harmonia 1.7 released, updated Gvoice search, Su, Gmail
1.8 14Apr12 Harmonia 1.8 released, includes Google Play Store, SU, Gmail, and a few other internal file updates
1.85 10June12 Harmonia 1.85 released, includes updates SU, updater, fixed installer, Vmroms, and fixed network location.
1.87 12June1 Harmonia 1.87 fixed kernel flash issue. removed due to wifi issues
1.9 12June12 Harmonia 1.9 fixed wifi, added Goo.im info
Versions:
Harmonia_1.90_OV.zip
MD5: 3dd9a415e69f9ec8b1a1c517dcbfde08
Harmonia_1.85_OV.zip
MD5: c5c816cb58c2cf6f052cfaf35519665d
Harmonia_1.8_OV.zip
MD5: b3a6d83617596325e9465fc6982885c9
Harmonia_1.7_OV_1+2.zip
MD5: da2c2174eb2c369fca9519fa823a718a
Harmonia 1.6.1c_Edify
MD5: 9832a1fdced8a98b7cd07932a466e2b7
Harmonia 1.6
MD5: ee3f5eb33177fa4deab339976d887495
Harmonia 1.5E Edify installer (lacks proper storage space)
MD5: 8a7c4f9a847ad954519f0e247099d5af
Harmonia 1.5 Edify installer BAD!
MD5: 64819df805b02822aa0bcd26b8c4edbc
Harmonia 1.3
MD5: ffcc96637995a5f45027f2c8cf1797ee
Harmonia 1.3.1 patch
MD5: 41eab570e10116cff704f489f6255822
Harmonia1.2.zip
MD5: 1e53fd8eea6ca28a8f87a298f858347b
1.1.1 patch fixes a few programs force closing (Yelp! being one of them).
Harmonia 1.1 to 1.1.1 Patch
Harmonia 1.1
MD5: 374beccefc7e4c63a496cf1f6152d947
Harmonia 1.0
MD5: 46fdde6f41d0f4beb9720ada22166284
i downloaded Harmonia_1.90_OV.zip
MD5: 3dd9a415e69f9ec8b1a1c517dcbfde08 and i am getting the error message the application google services framework (process com.google.process.gapps) has stopped unexpectedly. please try again and some about application email force close alone with when i click the phone icon to make a call it says application is not installed on your phone i am a noob and not sure what i am doing wrong or what is going on.
I'm so glad to see you added a way for us to donate to you! I haven't been in this thread for a while, but just popped by tonight and saw the donate link, and made my first one...probably will be followups, LOL.
Question...the changes to the newest version of Harmonia include you adding Vmroms...can you tell me what that is/does? Also, what is Goo.Im? And, final dumb question, but what does the Harmonia Updater do? I'm sure it's hard to be patient with non-techies like me, LOL.
Thanks for all your awesome work! I've loved Harmonia...only ROM I've used since rooting.
Thanks.
Vmroms is a forum app.
Goo is an updating system, but last I saw it didn't support the OV. This isn't included in 1.9.
The Harmonia updater is a tool to easily check for any updates, however odds are this rom will see very few updates from here on out.
Thanks.
Good to know,thanks! I'm currently running Harmonia 1.8 with no issue except fast-draining battery. Do you think I should update to the newest 1.9? Should we always update? LOL...sorry to sound dense, but it's an honest question... Cheers!
Thanks.
Fast draining battery can be traced to a rogue app. Harmonia itself is very efficient.
If 1.8 works fine, there's not a lot of need. If you happen to do a refresh though, I would update it then.
Good to know, thanks. I'm trying to figure out which app is eating my battery and all my battery monitor is telling me is that "Android System" is eating most of the battery life.
Is it a good idea to refresh the ROM every so often? Would that entail a complete wipe and reinstall? Not familiar, so thought I'd ask. Thanks again!
I like to reload everything on occasion to keep it fresh, some roms become unstable as they age, some much faster than others. However, it;s only been recently that I have been able to really keep a phone the same for more than 3 weeks before I ended up messing with it. LOL
Sometimes just clearing cache helps a lot to get rid of clutter. Otherwise, you can just wipe cache, data, and Dalvik in recovery and that will clear it out, then you can just restore your apps and data with Titanium or Mybackup. Other times a full re-install would be best.
OK, sorry to bug you with all these questions, LOL. but I do think i'm going to update to 1.9. The last time i did 1.8 I needed to use the pica07remix.zip to fix my newer screen problem (it did the nonresponsive "black screen" thing when I flashed 1.8 initially). Do I need to use this pica07 again for flashing 1.9?
Also, I used your other program, "prep for new rom.zip," which is awesome. Can i use that again to do all the wiping/clearing that needs to be done before flashing the update?
TIA!!
CrazyParis
