[ROM][ICS][4.0.4][5-15-12][WIP]supersonic-ota-eng.deck-pb25
Re: [ROM][ICS][4.0.4][4-12-12][WIP]supersonic-ota-eng.deck-pb20
OP has been updated with latest build. (pb20) Contains daily bug fixes. :)
Sent from the greatest HTC EVO 4G ever made!!!
Where is he hiding build pb20? Only newest I see is pb19 in his public folder. :confused:
I may have to try this. I always use Deck's but I just started flashing ROMs again.
Well, this is one heck of an awesome ROM to begin flashing again with. I will be flashing as soon as I get the chance. :D
Digging the ROMS...keep it up man. On update 20, noticed that the camera was inverted both vertically and horizontally. didn't notice it on update 18.
Is the front camera working?
Also I've noticed a few random reboots when using the browser or searching on Google Play. I think its the keyboard? Maybe? I havent really been able to accurately replicate it and also it doesn't wont to do it when I have logcat going.
Other than that LOVE THE ROM. Been using it as a daily for the past week.
Hey guys, I've got a couple questions here.
I'm using the Mason kernel v0.14 with hwa, fso, and sbc. Does this rom and kernel work with v6 supercharger and cod tweaks? And what is the best governor for the mason kernel at the moment?
Try it and let us know! That's what a pre-beta is all about, your testing information is VERY valuable at this point. This ROM is still early, it's lucky to be running at all, never mind questions about adding in different kernels and scripts and such. Since you just joined and this was your first post, review the past comments for recent versions and you will see what works and what doesn't. Help us test the ROM or please be patient on asking the advanced integration questions.
Alright so I'm trying out the latest release pb22. It's not bad! Smooth, clean, crisp. However I noticed apps I use a LOT such as google+ closes when I attempt to start a hangout. That I'm assuming is due to the front camera still not working.
As mentioned earlier I don't belive 4G/Wimax is working, then again I'm right outside 4G area. I'll try and test it but I dont think that's working.
The main thing as I'm sure for all is the camera. The front camera doesn't work. The back camera works and takes great photos. Is there a way for the auto focus to be turned off and as users have that control before taking the pic. Maybe it doesn't matter, but it seems to do ok when focusing. The camera is also very fast taking the picture as well. No hesistation.
I did get a reboot.. On this pb22 did I need to install GAPPS or was that included. I installed ics gapps but somehtng tells me I didn't need to. If someone can confirm I would appreciate it. Overall it's not a bad app. The front camera is the main issue at this point and I think ppl will use this as daily ROM.
I also use GPS ALOT!! So far it works ok.. there was one FC but I haven't really put it to the test.. I will report back later as I will put GPS to the test today.
These are things espcially GPS that should be fixed well.
However my request is the front camera.. Is there not a file from a different ICS device that could be imported to the EVO for it to work? It seems it just needs to be "turned on" and it's there.
So far so good.
:cool:
Reactions: tayl428
So far so good.
:cool:
As stated in the OP...Do not flash any gapps file with this ROM. They are built in.
Reactions: nygjay#AC
Thank you for letting me know the build was out. OP has been updated accordingly. :)
Sure. And thanks for the reply. I flash the from again to see if that stops some Fc's
Sent from my Swagurious HTC Evo
Re: [ROM][ICS][4.0.4][4-13-12][WIP]supersonic-ota-eng.deck-pb22
Ok after testing pb22- I went to start a movie on Netflix... It doesnt work! I thought EVERYTHING was working on the past builds?? Am I missing something..
How does the Evo not have video showing on Netflix?
Netflix video hasn't been working since one of the early alphas. With the addition of the hacked hardware acceleration and OpenGL drivers, the video rendering has become unstable. Since we still lack compatible kernel source for ICS, and there will never be an official ICS kernel for the EVO, the devs are doing their best with what we do have. This is still a work in progress, thus why it's still in pre Beta status.
Current ROM (BootManager Slot 3): MikG v3.11 w/ICS Lite Theme | Kernel: Underworld v0.1 SBC
Any word on video/hardware to work..I can see myself using this as a daily ROM. The best out there. Haven't seen anything else
I haven't flashed pb22 yet but I'm running into the dreaded 9016 VVM mms issue. This ROM doesn't included Sprint VVM to unsubscribe from these damn messages. regular voicemail working fine and showing notifications, but also sends a text with voicemail notifications. Suggestions?
The generally accepted way is to use an SMS app like GoSMS and blacklist the number. GoSMS runs circles around the stock SMS app anyway, it's fantastic.
sakebma2
