[ROM] ICS Elite Final - Aeneas Build
please please reupload rom sendspace says it is expired if you cant may ypu tell me ne other place to find this awesome rom i have CM9 n my internet no longer worked had to recover back to stock im new to this and all ki know was self taught with help from this amazim
site Thank You devs you ave all inspired me to follow dream
This is NOT an ICS ROM, it's just an ICS theme, if looking for an actual ROM for the Elite, download the Sleipner ROM , it's for our phone
Sent from my LG-VM696 using Xparent BlueTapatalk 2
i got stuck all the time in a reboot loop with sleipnir was it a mistake on my part or is sleipnir unstable
Curtis stopped development on this rom and took down links
Sent from my SPH-L300 using Tapatalk 2
@James Chapman2.... I highly recommend using the Sleipnir ROM, it's very stable, been using it since it came out, I suggest you go to the Sleipnir ROM thread at Android Forums.com & read it all, everything u need is explained, good luck
this is a lie, I downloaded and install the ROM mentioned here and it's a 2.3.7 ROM themed to look like ICS. And from what I've experienced the ROM doesn't read SD cards.....garbage
hi im trying to download your file for my optimus elite but the file is outta date please resend a link?
dmflowsjalallodhi
