[ROM] ICS SDK Port [WIP]
Status
Not open for further replies.
@Batting1000 - I use Rom Toolbox from the market. The free version can change density. See pictures.
Have you tried this with ICS? Just asking because there've been a few apps thus far that don't work :-)
Sent on Ice Cream Sandwich from the future of Android
Yes, the screeenshots have been taken with Vol Down and Power. Check the details in the picture and in my user information on my posts.
Short answer - Yes:p
@ Batting here's a flashable zip with the Download and Settings apk. Everyone can flash this if they would like to get the updated look. To see exactly what it looks like just back a couple pages Batting posted the screenshots. Thanks.
If you are the type that doesn't want to flash you can download the apks from Batting's post or download the zip extract the apks. Place both apks in the android sdk foldr that has adb in it. Then at the command line run the following.
Code:
adb remount
adb push DownloadProviderUi.apk /system/app
adb push Settings.apk /system/app
Either way works I tested both ways.
I used Batting's tutorial, but now my Settings icon is gone from the Google Apps container on the home screen. How to get it back?
Never mind...I figured it out. :-[
-laughs- Sorry. Big derp moment for me there. Awesome though, thanks for the tip on the app!
Hey Beezy is there anyway you can bump up important/update posts to the top of the fourm? Tired of searching through the posts :D
Someone a while back mentioned turning off the GPS location and I've found that monumentally helped. Just sayin' :-)
Thanks for the info. I just turned it off, I'll run it for a few days and see how she goes.
I seem to only get my battery to charge to 96% with this port. I was getting to 100% in GB before I flashed this. Anyone else having this issue?
my nexus never have got 100% always 96% the only way to get 100% is wifi hotspot and screen on till 100 %
Hey Beezy.. This is my first attempt to root and flash a new ROM on a phone. In my case, I'm on a Sprint Nexus S.. Just want you to know how much I appreciate your efforts and keep up the good work.
no one knows how to get the "data usage warning" to go away? says "usage exceeds 2.0 GB" & showed up while I was tethering.
Sent from my Nexus S 4G using Tapatalk
I need the launcher though. Deleted it on accident
I have your original launcher2. Will it work with 3.6? Or should I just wait until Beezy puts out another update. I could send it to you as an email attachment. I don't have any online public storage sites.
guys. question.
my messaging is too short. i cant type more than 120 letters i think. is there any option to expand my sms?
thanks alot guys! :)
guys. question.
Without actually going in and changing the code that puts a limit on the Mms.apk...
Try GO SMS or Handcent... Both are way better than stock anyways.... I know GO SMS works, I've had it running without issue..
Reactions: myxpod32
Is anyone else having load issues with Netflix 1.5 the newest update??? it refuses to load. The all red netflix screen will attempt to load then flash back to the home screen.
This thread is massive; I read ten pages or so and ran a search, but nothing really concrete came up. Is there a fix for the Music not streaming? I full wiped/Dalvik wiped/resycned/resetup and nothing seems to work. WiFi and 3G both just bring up the song but never start streaming.
Otherwise, awesome work on this. I love just about everything. Going back to GB seems so primitive now.
Status
maryhurst515
