[ROM] Incredibly Re-Engineered v2.3 [02-8-11] Fast, Beautiful, and Simply Magnificent
Nandroid backups are full system images of your device at the time the backup was made. They are not good for restoring apps to a new ROM. Nandroids are all an or nothing recovery tool.
To backup data between ROMS - Titanium (and there others on the market but I use Titanium so I'll use it as the example) is good for backing up data when moving from ROM to ROM. However, let's think about what really needs to be backed up...
e-mail - Gmail is saved on the Google Servers so no need to back that up. POP/IMAP Exchange email is also backed up on the mail server so again no need to back that up.
Contacts - Gmail contacts are automatically backed up to Google's servers. Phone contacts can be backed up using the export/import function in the contacts app.
Bookmarks - Titanium backs up bookmarks and this is one of the very few pieces of system data that can be restored on any phone.
Apps - What apps really need to be backed up? Apps that hold state or current progress information and that's it.
Apps like Angry Birds (as an example) store your progress locally and if you do not back it up you will lose your progress, so game data can be backed up and restored.
Bank apps? Nope - everything is on the bank's server. just re-download and login.
Weather Channel? Nope - the handfull of locations you can monitor can easily be re-inputed after a fresh install.
Beautiful Widgets? Nope - If you have the paid version, you can re-download from the market and re-set up your preferences. If you want to save the data so you don't have to re-download skins then this is another where you can restore the data after re-installing the app.
The big advantage to backing up all your apps with TI is that you have a list of what was installed. You are better off doing clean installs from the market for apps that do not hold state. Another way to manage which apps you had installed is to use AppBrain, it will sync what apps you have installed but AppBrain does not save data.
SMS - Now this one is a personal thing. I don't care if I lose my SMS. I don't hold every text message as if it were a precious illumination by DaVinci, however I know that some people do. There are apps in the market that will restore SMS messages, even when moving between ROM's but they are not a fix all. If problems develop after restoring, then you want to roll back that restore.
Other than that, what else needs to be restored from an old ROM? Any config?s or screen setups would have to done over again anyway. You would want to take advantage of any features the new ROM has so restoring old setups will do more harm than good.
So, after a very long-winded dissertation, Titanium is good for moving from ROM to ROM, you just need to be knowledgeable about what is safe to restore and what is not safe to restore.
Good point. There is not much to back up except games. All the other data is saved elsewhere or you just don't need it. I think from now on I won't restore all missing app and/or data!!
Thanks guys for all your help!!
Ok so I'm still getting the random app stops (tweet deck, power amp, internet, google framework, etc) any clue whats goin on and how can I fix it?
no, i haven't done a thing, it just suddenly started. i can't do anything on it right now, all apps are randomly shutting down..."sorry application.... has stopped unexpectedly" has popped up for just about everything. would like to get my phone up and running normal again, please help, thanks.
Try running Fix Permissions in Recovery. It's under Advanced.
I've run into this problem before recently too. Just uninstall the app and reinstall it and it will work fine.
I am getting the same error that other people are getting too. I wiped everything and i get this error "it was necessary to remove it when upgrading to the clockworkmod 3.0 gingerbread based recovery. Please switch to edify scripting (updater-script and update-binary) to create working update zip packages."
Someone help with this. I really want to try this rom.
If anyone was having the same problem as me where they couldn't flash this rom because of the problem above, I finally figured it out. The reason being that none of his rom's work with any version 3 of cwm. If you install version 2.5.1.2 then you can install the rom. On dougpiston.com you can download it.
http://dougpiston.com/files/Recovery/recovery-clockwork-2.5.1.2-inc_PB31IMG.zip
here is the link to cwm 2.5.1.2. Just rename it to PB31IMG and install in HBOOT. The go into CWM and install Incredibly Re-Engineered.
i had this problem.
the links for the download are out of date.
i tried v2.3.1 the other day for a few hours and everything i tried worked but i couldnt figure a few things out.
is flashing the mods the same as flashing the rom except you dont wipe anything?
i cant seem to get a grasp on how that part is done...
so phone was pretty much a paper weight on sunday...decided to reflash ROM, working great now....but i do hvae to ask
-is there a way to prevent this from happening again
-still need to figure out how to update google maps and facebook, will not install from market...thanks.
I installed this one a couple of times yesterday. Kept having problems with apps. I think I got it figured out now. Here's the troubleshooting process I used:
After clearing all the memory, etc. I flashed the ROM.
1I restored apps from Titanium Backup, then fixed permissions.
Apps that wouldn't update got uninstalled and reinstalled.
Then, as needed, I restored data for individual apps.
And of course, I had to reboot after each step.
anyone having problems with pandora or slacker?
slacker keeps saying press play to reset station but it doesnt do anything, and pandora doesnt ever make any sound at all and wont ever load a new song...is there anything i can do? i already reset and reinstalled but still the same problem
help
throwing in the towel...have followed all steps to a T and still phone continues to crash and force close EVERYTHING and at this point have lost all my data in the process...giving CM7 a shot, hopefully that goes better
Try the latest CM7 nightly. It's very stable and I haven't had any problems with it.
Sent from my HTC Droid Nexus with Tapatalk.
r3dpuk3
