mmarz is the man!I will try it right now and let you know
mmarz is the man!
lol @ your commentsI totally read that as "mmarz is A man" and I was going to ask are you sure?
And IF so how are you sure?
lol @ your comments
and
rofl @ your picture posted
I thought MMS was working on this ROM. I tried sending one from the phone and it sits there with sending... in the message. I tried sending one to the phone message arrives but won't download the pic. :'(
That sounds like your data connection. The mms error, when it occurs, sends the message from some weird number and shows Chinese characters.
I'm using WiFi connection.
Update: Switched to 3g connection and it sends and recieves fine. Wierd that it didn't work when using Wifi.
It's always been this way. You can only send via 3G
I can't get mms to work at all. Are there any troubleshooting steps I can try to resolve this? Thanks in advance
do you have wifi off and 3g on?
Android has always turned off 3G Data when wifi is on, so MMS won't get through without data connection. I believe this is true in Froyo and Gingerbread ROMs. If anything, this is a Google Android issue.
Idk, mine temporarily turns on 3g automatically along side wifi to download the mms.
No this isnt true.Android has always turned off 3G Data when wifi is on, so MMS won't get through without data connection. I believe this is true in Froyo and Gingerbread ROMs. If anything, this is a Google Android issue.
No this isnt true.
asop's rom once he got mms working would download mms even while on wifi.
I normally am on wifi and I still get my mms.
The only time data is off totally is when you shut it down.
I think if people are having a problem with it not working with wifi on its a kernel issue not allowing the mms app to wake up the mobile network.
